Question on Comptech subframe bar/rearsway
Old Apr 9, 2010 | 08:48 AM
Rhetoric's Avatar
Default Question on Comptech subframe bar/rearsway
Just picked up a Comptech subframe bar/rearsway kit used for my 2000 hatchback. (Check out the PDF attached for picture reference)
The kit did not come with the endlink brackets that are to be bolted to the lca's. My question is could I connect the endlinks (which are adjustable) directly to the lca, possibly using washers/spacers to get the correct line (which I think is the purpose of the endlink bracket?).
Any help would be great.
Thanks
File Type: pdf
Old Apr 9, 2010 | 08:51 AM
ChokolAwt's Avatar
Default Re: Question on Comptech subframe bar/rearsway
you need to source some end links...
Old Apr 9, 2010 | 10:45 AM
98civdx's Avatar
Master Detailer
it looks to me like you will need the brackets, or you could just make something to fit like the brackets do.
216.226.142.95:27016
Suspension & Brakes
Jun 21, 2005 01:41 PM
irev210
May 5, 2004 08:17 PM
96 SOHC VTEC
May 9, 2003 09:20 AM
GSR-REX
Oct 8, 2002 05:00 AM
