9003 H4 headlight adapter w/relay
Old Apr 9, 2010 | 07:07 AM
crx_si-r's Avatar
Default 9003 H4 headlight adapter w/relay
i saw this on ebay the other day, and was curious if this will work. i know on newer cars like my EJ8, the headlights use a single dual filament bulb. but on ours they are 2 single filament bulbs. on the dual filament bulbs i know the low beam kicks off when the high beam is turned on.
so here is my question: will this work to cut the power to the low beams when i use my high beams on my JDM EF8 headlights (they use h4h bulbs, but the plugs for the lights are the same). or has anyone hooked up the the headlights the correct way using just standard relays? thanks in advance guys.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Eddieman201
Mar 25, 2007 03:57 PM
FakeJDMEF8
Oct 18, 2004 04:00 PM
13BT
Apr 9, 2003 07:22 AM
greensleeper
Jul 26, 2002 12:42 PM
Calvin Lai
Jun 4, 2001 12:38 PM
