Spherical End Links for Mugen Rear Sway Bar?
Old Apr 8, 2010 | 08:17 AM
GUILOTINE's Avatar
Kill Gil
Icon2 Spherical End Links for Mugen Rear Sway Bar?
Has anyone found or is using adjustable spherical endlinks on their "Mugen 26mm" ITR rear sway bar? If so, what brand and part number are you using?
I tried using the blox endlinks but they did not bolt on to the bar becasue the diameter of the whole was smaller. I don't want to go through the trouble and expense of buying ASR/Function7/ and every other brand trying to find one that works.
Thanks in advance guys
-Gil
Old Apr 8, 2010 | 11:34 AM
Mike M's Avatar
Founding Member
Default Re: Spherical End Links for Mugen Rear Sway Bar?
Won't work, sell me your 26mm bar and I'll send you the stock one so you can use those end links :p
Old Apr 8, 2010 | 02:40 PM
GUILOTINE's Avatar
Kill Gil
would you like some cash on top? I really don't want to rip you off
Old Apr 8, 2010 | 03:34 PM
omiehomie's Avatar
gill try function 7 i think they have what your looking for...
Old Apr 8, 2010 | 04:12 PM
97ITR#126's Avatar
Lol
Old Apr 8, 2010 | 07:21 PM
iheartintegras's Avatar
Guil, have you looked into the 32mm hollow ASR sway bar set up?
Old Apr 8, 2010 | 07:27 PM
get RIGHT's Avatar
I use stock endlinks are on my 26mm bar. I have never seen spherical endlinks for a 26mm bar but I wouldn't be suprised if there is one out there.
Old Apr 8, 2010 | 08:45 PM
white rocket's Avatar
Gil, I tried using the Function7 spherical endlinks on my Alex 25mm rear bar and they didn't work. I ended up just using the stock ones. You can most likely rule those out.
Old Apr 8, 2010 | 08:52 PM
Mike M's Avatar
Founding Member
No not unless you want to :p
Old Apr 9, 2010 | 09:04 AM
GUILOTINE's Avatar
Kill Gil
It looks like a nice piece. I might consider upgrading to it if I can't find adjustable end links for my mugen bar.
Old Apr 9, 2010 | 10:45 AM
rzz's Avatar
rzz
was it too short?? how it doesn't work..? since i want to upgrade to spherical endlinks as well for my alex 25mm rear bar as well
Old Apr 9, 2010 | 12:40 PM
GUILOTINE's Avatar
Kill Gil
I belive the diamter of the whole in the sway bar busing is much smaller than the one used in the Blox spherical end link kit FWIR.
Old Apr 9, 2010 | 12:48 PM
Mike M's Avatar
Founding Member
You mean the hole on the end of the bar? just open it up a bit, will be fine.
shahriar35
Jan 19, 2015 04:22 AM
fso_BamBam
Apr 8, 2006 08:29 AM
jwaked
34
Nov 25, 2004 09:22 PM
Todd00
Jan 16, 2002 09:10 PM
