Help with 89 crx
Old Apr 8, 2010 | 06:21 AM
honda20crx's Avatar
Default Help with 89 crx
The other day i was giving my car a tune up. I changed the spark plugs, spark plug wires, distributor cap and rotor, and fuel filter. Now my car wont start. It turns over but wont start. I know that its getting spark and checked all the spark plugs. the wires on the distributor cap are in order too. This seems like an easy fix but iv tried everything i could think of.
Old Apr 15, 2010 | 06:39 AM
honda20crx's Avatar
Default Re: Help with 89 crx
Anybody?
Old Apr 15, 2010 | 08:55 AM
B18B1-Crx's Avatar
Check and see if your getting fuel past the filter.
Make sure your rotor is put on the right direction.
Check your spark plug gap.
Does the motor run at all?
Does is backfire?
what else could you have done to effect it?
Old Apr 15, 2010 | 09:03 AM
SeeAreEx!'s Avatar
coulda accidently disconnected the ignition
Old Apr 17, 2010 | 08:24 AM
honda20crx's Avatar
I checked fuel filter and lines and im getting fuel past the filter.
the rotor is installed the right way, the rotor could only go on one way.
The spark plugs are gapped correctly.
The motor turns over but still no start.
i forgot to mention this but i also replaced the pcv valve and hose, ignition coil, and main relay.
Still no start.
Old Apr 17, 2010 | 08:56 AM
jrose152's Avatar
sounds like a fuel issue to me
Old Apr 17, 2010 | 12:23 PM
SeeAreEx!'s Avatar
mostly certain it could be your ignition system.. make sure everything is connected the right way. since you did mess around with the ignition coil.
Old Apr 17, 2010 | 12:45 PM
hondab88's Avatar
might sound silly but when you replaced the ht leads did you remember the firing order? are the plugs soaked with fuel?
Old Apr 19, 2010 | 12:24 PM
honda20crx's Avatar
The ignition system is all connected correctly.
I went back and checked if i have the firing order right and it is.
I also went back and looked at everything i did. And i still dont know why it wont run
Old Apr 19, 2010 | 12:51 PM
EF_typeR's Avatar
This happened to a friend of mine...
Assuming that ur injectors are spraying fuel, i would check to make sure that ur spark plug wires are actually contacting your spark plugs. It may sound stupid but alot of people over look this and just assume their getting spark to the cylinder automatically.
Make sure that ur plugs arn't fouled out from cranking it over too much with no spark, and take the top boot off the plug and feed the wire down through it some to make sure there is enough length for a good connection. Then pop her on till u feel/hear the clicking of it grabbing the spark plug.
Hope this helps.
Egkid95
10
Dec 15, 2014 09:33 AM
MATiC
Jan 27, 2007 08:28 AM
vheissu
Nov 6, 2005 06:10 PM
xagix
12
Aug 21, 2005 11:28 PM
