Suspension & Brakes Theory, alignment, spring rates....
4040 install?
Old Apr 8, 2010 | 04:21 AM
RamSST's Avatar
Default 4040 install?
Trying to figure out how to properly install the 4040 valve in my 95 teg, but the one piece of info I can't find is what fitting is supposed to go to what brake.
Old Apr 8, 2010 | 06:27 AM
Trey's Avatar
25 Year Member
Default Re: 4040 install?
You unbolt the current prop valve and bolt on the new one. The hard lines go back in the same orientation.
You'll need a Bleeder Wrench so you don't strip the threads too. 10mm.
Old Apr 10, 2010 | 10:04 AM
RamSST's Avatar
yes but your going from 2 outputs to 4? do the new outputs go to the fronts.
Old Apr 12, 2010 | 10:52 AM
Trey's Avatar
25 Year Member
The EK chassis is just a direct swap. Dunno about the EG chassis. Sorry for the confusion.
mmcsiggi
Suspension & Brakes
Oct 28, 2010 03:32 PM
slimjimdanny
May 1, 2007 04:21 PM
Mach69
17
Nov 23, 2005 07:01 PM
