SOHC engines (96-98 ZC and Y8) and PARTs
PICK UP ONLY PLEASE!!!! OR ILL MEET HALFWAY FOR EXTRA 20 BUCKS FOR GAS!
96-98 SOHC ZC motor 99% complete swap into any chasis. WILL NOT PART OUT!!!!!
-Y8 Transmission
-Y8 Intake Manifold with 60mm GSR TB
-Barely used Lightened Flywheel
-Barely used Stage 2 clutch and pressure plate
-Distributor
-Alternator
-Starter
-Has power steering unit
-Spark plugs and wires
-Rear T Bracket
-Shift Linkage
-Short shifter
-Mounts
-Best thing is the motor has less than 37K miles on it.
-Does not include: Engine Harness, shift ****, ecu or headers.
PRICE: $700
-Edelbrock D series Headers CARB LEGAL: $350 in great condition discontinued and is one of the best headers for D's ;p
-AEM Intake Carb Legal with filter and clamps for bolt on: $100
Spare D16Y8 almost complete engine (motor needs a rebuild on the bottom end) spun rod bearings.
has all:
-ZC intake manifold and TB
-starter
-alternator
-stock clutch and pressure plate along with stock flywheel
-Head is all intact in perfect working order
-EX transmission slight grind in 3rd gear
PRICE: $300
IF YOU WANT IT TO BE PARTED OUT:
-Y8 Head: $150 perfect working order (does not have the distributor)
-Transmission: $100 easy third gear swap out
-Shortblock: $60
-Alternator and starter: $50 together
DOHC parts
-OBD1 GSR uncut HARNESS: SOLD!
-Exedy Stage 1 Organic clutch with less than 5K miles, just barely broken in: $185.
-Vortech Fuel regulator: $35 shipped anywhere.
-AEM (RED) fuel rail: $55 shipped anwhere.
-ITR CALIPERS with 23T brakets all bead blasted and cleaned! $120 shipped anywhere.
-Y8 Transmission
-Distributor
-Alternator
-Starter
-Rear T Bracket
-Shift Linkage
-Short shifter
-Mounts
PRICE: $700
has all:
-starter
-alternator
PRICE: $300
-Shortblock: $60
DOHC parts
Locatd in Fresno guys. hit me up if you guys are interested. Im paypal verified! 559.916.7026 -Ko
-1991civic its a fuel regulator not fuel management unit.
oh yeah ZC is still in my car, if you want to test it out be my guess but give me a call and make sure you have a deposit down waiting.
kantfadedisazn
Feb 15, 2006 01:02 PM
crxcess
Jul 24, 2003 02:29 PM
[626]phixionEF91
Oct 14, 2002 11:12 AM
