how do i read the ecu codes?
Old Apr 7, 2010 | 10:28 PM
crazy bum's Avatar
Default how do i read the ecu codes?
well i was wondering how to read the codes on the ecu in my hatch.its a 91 d15b7..and how to fix the problem.
Old Apr 7, 2010 | 10:49 PM
BrayzieEF9's Avatar
Default Re: how do i read the ecu codes?
check the faqs section it has everything u need
Old Apr 7, 2010 | 11:27 PM
sh!ft's Avatar
Who the fack changed my title?!
since portland is being a lazy douche ill anwer, pull the carpet back on pasenger side and you'll see the ecu. it wil flash a consecutive number of flashes. if it flashes a different pattern, then each different pattern(1 flash= code 1,4= code4 ect) means another different code.
Old Apr 8, 2010 | 09:45 AM
crazy bum's Avatar
lol.sorry i wasnt accurate at all on my post but i meant, how many blinks is what,i just re checked mine right now and it went, 6 pause, 17 what does this mean?
Old Apr 8, 2010 | 09:46 AM
sh!ft's Avatar
if its just those two then you have codes 6 and 17.
Old Apr 8, 2010 | 09:55 AM
crazy bum's Avatar
yah its just those 2, i found this site right now http://www.downtoground.net/knowledgebase/?p=7 , if these are my problems how could i fix it?
Old Apr 8, 2010 | 12:08 PM
BrayzieEF9's Avatar
lol lazy douche?? I was pointing him in the direction of ecu codes list.so he can troubleshoot it
Old Apr 8, 2010 | 03:39 PM
crazy bum's Avatar
lol.okay lets not start any online fights if thats where this is going, its pointless, but check out that site i listed, http://www.downtoground.net/knowledgebase/?p=7 , im not a car pro or anything but how could i fix this? the error codes read 6 and 17..
Old Apr 8, 2010 | 03:56 PM
BrayzieEF9's Avatar
well 6 water temp sensor and 17 is vehicle speed sensor.for 17 check your VSS and see if the sensor is broken or not,if not.make sure to put it in all the way til it clicks and make sure you have the clip that locks it in place and number 6 you probably need a new thermostat
Old Apr 8, 2010 | 05:58 PM
crazy bum's Avatar
i think the vss is broken, its where the speedo cable goes in right? if it is, there was a piece that was broken...as for the thermostat where is that located? there are many cars like mine at the junkyard so i can go pick one up there next week
Old Apr 8, 2010 | 06:26 PM
BrayzieEF9's Avatar
yes the VSS is the cable that goes into your tranny.you can buy a new one at the dealership for like 20 bucks.well i can lol since i get discount.so replace that and just follow your lower radiator hose to your thermostat.should be below your intake mani
Old Apr 8, 2010 | 07:14 PM
crazy bum's Avatar
the vss i picked up about a week ago at the junkyard...when i pulled it out the motor was sitting on it, forcing me to pull up the motor and have someone pull the cord out, the rear and right side motor mount was off..so if i get another one the problem should be solved..?
Old Apr 8, 2010 | 07:17 PM
crazy bum's Avatar
i was thinking about making a new thread but since were on the radiator , does anyone know why mine turns on when i turn the car on, not starting the car before that..it comes on is that a bad thing? either way if it is or isnt how could i fix this?
Old Apr 9, 2010 | 12:02 AM
projekt90ef's Avatar
you mean the fan kicks in before you start? i cant understand your typing
Old Apr 9, 2010 | 08:49 AM
crazy bum's Avatar
yah sorry i was playing some xbox live when i was typing, call of duty! funn lol.but thats what i meant the fan starts when i turn the car on, before i fully start it, and it seems alittle loud too..i wanna fix this i find it weird that this happens
Old Apr 9, 2010 | 12:11 PM
nothing wrong with the rad fan blowin down ur motor....check your coolant level.
Old Apr 11, 2010 | 10:43 PM
crazy bum's Avatar
i know right, keep my motor cool hahah but it doesnt bother me that it turns on when i turn the car on, kinda weird tho never happened to me, but its just that it blows so loud, the coolant level could probly be the reason why it blows loud? how loud it was i put my camera behind my car to record the sound of my exhaust and you could hear the fan blown
SolScifen
May 19, 2013 11:35 AM
corps909k
Mar 25, 2009 09:56 AM
Type R CivIc
Apr 6, 2005 11:57 PM
ef_you_again
Mar 17, 2005 11:14 PM
kim_2_da_chee
May 30, 2003 06:18 PM
