How do you remove the OEM sideskirts?!?
Old Apr 7, 2010 | 09:09 AM
H23_del_soul's Avatar
Default How do you remove the OEM sideskirts?!?
I tried getting them off so I could get to my fender bolts, but I ****ed up the damn plastic clip towards the front! I Figured it would be easier to ask if I was missing something rather than pulling harder and ****ing something up worse than I already have. So do they pull straight off, or at an angle or what?!?
Old Apr 7, 2010 | 09:24 AM
NOOdS's Avatar
Default Re: How do you remove the OEM sideskirts?!?
you have a del sol right? well, i have a 00 hatchback.
im pretty sure sides skirts all come off the same way for hondas.
well, you should have a few screws in the front, inside the tire well. about 3 or 4 screws on the bottom of the skirt. then, you should be able to slide the skirt towards the front. it should come right off.
putting it back on is different from taking off.
Old Apr 7, 2010 | 09:58 AM
D Griff's Avatar
If it doesn't want to slide forward, try tapping the back of it with a rubber mallet.
Old Apr 7, 2010 | 11:19 AM
So slides forward, got it. I'll go and give it a shot, thanks for the help
Old Apr 7, 2010 | 11:43 AM
Matt93eg's Avatar
I have had to do it that way and it usually works like a charm. Don't have to beat it with the mallet..just taps. Putting it back on is easier. It just snaps back on and you put the screws back in.
Old Apr 7, 2010 | 01:05 PM
NOOdS's Avatar
to put back on...
take off the white clips off the car and put it on the skirt. just line it up to the holes and push it in, it should click right in. and just screw the screws back.
Old Apr 21, 2010 | 12:40 PM
Originally Posted by NOOdS
to put back on...
Worked like a charm Thanks for the tip man!!!
nthao89
Nov 30, 2008 02:01 PM
imacoolkid
Oct 9, 2006 08:31 PM
excel88
Jun 21, 2004 05:47 PM
dlslvtch21
Apr 11, 2002 11:30 AM
SwiftTypeR
Jan 24, 2002 06:10 AM
