Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 Honda Accord Windshield Wiper Motor problem
Old Apr 6, 2010 | 12:29 PM
Noch's Avatar
Default 03 Honda Accord Windshield Wiper Motor problem
My wipers stopped working a few weeks ago(the last snow storm). I didn't have time to look at it in depth till now but I took off the wipers and connected the power straight to the wiper motor and it worked so with that I assumed that the motor was fine. Ended up taking it to a local mechanic for a second opinion (due to lack of time)but he says wiper motor was bad and needed to be replaced. Is it possible the motor is still bad (electrically) or am i getting screwed by this guy?
*Also checked the fuse and they keep blowing. Any ideas? I think I'm next going to check maybe the wiring.
Old Apr 6, 2010 | 01:18 PM
Noch's Avatar
Default Re: 03 Honda Accord Windshield Wiper Motor problem
Any answers?
Old Apr 6, 2010 | 02:56 PM
BLKFLSH's Avatar
You should have checked the local dealership first. There was a recall on the wiper motor. You could have gotten the motor changed for no charge. If you are the original owner, you should have received a recall notice from Honda.
Old Apr 6, 2010 | 02:59 PM
BLKFLSH's Avatar
Old Apr 6, 2010 | 06:30 PM
numbvir's Avatar
Well done!BLKFLSH! this is what im looking for now.
Old Apr 7, 2010 | 04:28 PM
Ross 2.0's Avatar
In a Junkyard near you.
If you post your VIN I can check the status for you
Old Apr 9, 2010 | 09:22 AM
Noch's Avatar
thanks BLKFLSH but I had already called the Local dealer and they said it wasn't covered...and I believe there is a site to check to and I tried that also cause I wanted to double check, but it wasn't covered....its not one of those appearently...but i'm sure it is, cause it's the same issue and if i take it in Honda will charge just to look at it.
Old Apr 9, 2010 | 01:13 PM
BLKFLSH's Avatar
I would call another dealership, and try again. Did they tell you your car wasn't covered, or the part is not covered? Did you check Honda owner's link. You can probably enter your VIN # and find out if your car was included in the recall that way too.
Old Sep 14, 2016 | 03:18 PM
Trevor Boyer's Avatar
1HGCM56683A126536
ldfrs125
May 14, 2019 10:59 AM
mkfrl
Nov 14, 2018 04:45 PM
yvonne nelms
Feb 4, 2016 08:04 AM
