B16A Swap Problems. Need Help
i have a CRX SI, SI BRAKES ETC.
i have a swap i took from another crx,
B16a W/ xsi original tranny and i think mid shaft,
what axles do i use???
the ones i have are to long!
Since you have an XSi intermediate shaft, which is a DA. My best guess is that you'd need DA axles. But i'm not 100%...
Best best would be to source US DA intermediate shaft and axles. That would definitely work!
you need DA 90-92 axles non abs. make sure its non abs by looking at the ends of the axles that go into the rotor and make sure the part of the axle that touches the hub has no teeth (used on abs axles).1st picture is of ABS axles do not get these. 2nd pic shows the gear @ number 2. so make sure your DA axles dont have this gear.
HEY MY b16a+Y1 traNNY,
I BOUGHT 90-93 -- integra MID SHAFT AND AXLE!
the half shaft WONT BOLT UP AS THE CASTING ON THE B16a is different so it wont work!!
WHAT DO I USE???
WHAT DO I USE???
ncrx1
Dec 13, 2001 05:52 PM
