Suspension & Brakes Theory, alignment, spring rates....
swar bar question
Old Apr 6, 2010 | 09:21 AM
efjones9's Avatar
Default swar bar question
i have a st rear swaybar for my ef. only problem is that i dont have a front swaybay. not even a stock one, so will the performace suffer because of the lack of a front sway bar?
Old Apr 6, 2010 | 10:13 AM
alphalanos's Avatar
Default Re: swar bar question
No. Adding a front bar will bring some understeer. Unless you can find a cheap one at a junkyard, I wouldnt bother with it. It might make it feel a bit better, but in reality its just making the car push.
Old Apr 6, 2010 | 10:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yeah but having a decent-sized rear bar and NO front bar might make the car TOO tail-happy, especially during lift-throttle, whereas adding a front bar might make the car a bit more balanced.
Old Apr 6, 2010 | 11:09 AM
efjones9's Avatar
So an oem on the front wouldn't hurt but a aftermarket one may be too much in the corners?
Old Apr 6, 2010 | 12:04 PM
TunerN00b's Avatar
Entirely depends on spring rates, rear swaybar size, driver preference, tires, driving conditions, and intended use(s) of the car.
I could see skipping the front bar on track, but not while autocrossing. That is a personal preference and is not "the answer" for everyone, just me.
In other words, no easy answer here. Trial and error time, which is why starting with a cheap junkyard bar is a good start, to prevent wasting too much money if it isn't right for you.
Old Apr 6, 2010 | 12:11 PM
efjones9's Avatar
makes sense. thanx bro
made in JAPAN
Mar 15, 2004 05:18 PM
#26Type-R
Feb 27, 2004 02:50 PM
T_Rex
36
Jan 23, 2003 05:45 PM
sfr4dr
20
Sep 28, 2002 12:09 PM
AdamITR
10
Aug 22, 2002 08:58 PM
