Car drops rpms/shutters w/ ac on.
Old Apr 6, 2010 | 06:24 AM
georgiajdm's Avatar
Default Car drops rpms/shutters w/ ac on.
Car is an 01 5 speed.
I've backed the idle screw out as far as it'll go to get the rpms to idle at 700-800 with no load. With the ac on it'll sometimes idle down to 200-300 and shutter, makes it feel like the engine is going to stall out. I've checked the vacuum diagram and no leaks that I can locate. Why are the rpms dropping like that? Isn't the car suppose idle higher with a load (ex. ac) on?
Old Apr 6, 2010 | 07:22 AM
Sr420Det's Avatar
Default Re: Car drops rpms/shutters w/ ac on.
maybe eld or ur idle bypass valve is clogged.
Old Apr 6, 2010 | 08:49 AM
white92lude's Avatar
i have the same issue, id like to know how to fix it
Old Apr 6, 2010 | 09:05 AM
Sr420Det's Avatar
Do u guys have a cel on? Have u tried cleaning the iacv?
Old Apr 6, 2010 | 04:28 PM
georgiajdm's Avatar
no cel.
Old Apr 6, 2010 | 04:44 PM
zxtuner98's Avatar
clean the IAC. Its normal for it to drop like that when the compressor kicks on and off..
Rooftop-Special
Sep 2, 2010 08:08 PM
Andrew14
Jun 22, 2010 09:24 PM
an2ny888
Aug 4, 2004 04:33 PM
vietboixstunnah
Aug 7, 2003 12:41 PM
