Transmission Problems!!
I have just recently purchased a 99 LX from a friend, when driving it around for a little while I noticed that it was shifting a little hard into second gear (Auto Trans) thought nothing of it. Then the other night as i was driving around I started to get a little bit of sputter out of it, I accelerated to see if it would work it self out but kept sputtering as if the trans was engaging and releasing, I hit the acceleration again but this time its completely released, None of the drive gears are engaging and Reverse is not either. I turn the car off for a little while and then put it into drive and it starts to move only to release about 45 seconds later. I flushed the system but knew it wasn't going to do much anyway I'm locked on the thought that its one of the solenoids on the transmission but I don't know which one. I would replace them all but I'm sort of strapped on cash. I've searched the forums for a little while and came up empty I could really use some help
Thanks,
Rich
Thanks,
Rich
No it just shouldn't be the pump in the fact that it will shift through the other gears just fine. If i lift up the front end and put it in drive it will shift all gears fine and hold, Its only between gears one and two
20-EM2-05
Honda Civic (2001 - 2005)
Mar 13, 2010 08:57 AM
DougNuts
Dec 19, 2007 05:39 PM
