b16a vs. ls/vtec
Old Sep 9, 2002 | 08:11 PM
b16coupe93's Avatar
Default b16a vs. ls/vtec
want to know weather to go with a b16 swap or an ls/vtec in my 93 coupe i have also considered a b18c gsr ,, i want to get the most power and reliability for my money
Old Sep 9, 2002 | 08:14 PM
ill phil's Avatar
Default Re: b16a vs. ls/vtec (JDM93Eg)
Power and reliability for the money- I'd say B18c. I have a b16 and am relatively happy with it. But I can tell you it really needs more torque. The LS-Vtec can be pretty impressive too if its well built and can still be pretty reliable.
b16
b18c
Old Sep 9, 2002 | 08:19 PM
FifthGearOnline's Avatar
Default Re: b16a vs. ls/vtec (ill phil)
Do you want torque, or not
Old Sep 9, 2002 | 08:22 PM
EpDarks's Avatar
A B16 a is in a way different leauge than the LS/VTEC.
LS/VTEC's are torque monsters from the darkest recesses of hell. B16's have NO ***** under 4000 RPM.
However, B16's are going to be way more reliable than the LS/VTEC.
I'd say go with the middle ground B18C1.
And I drive an B16A2 by the way.
Old Sep 9, 2002 | 08:23 PM
Default Re: b16a vs. ls/vtec (EpDarks)
why not just get a B18B and NOT do the vtec swap........reliability AND torque
Old Sep 9, 2002 | 08:27 PM
Unjockable's Avatar
New User
Default Re: b16a vs. ls/vtec (FifthGearOnline.com)
I'd go with either B16 or B18....LS/Vtec is not reliable.
CRXSleeper's Avatar
In terms of price, is a B18b and B16 swap about the same?
Old Sep 9, 2002 | 08:28 PM
broke1's Avatar
i had a ls motor and was happy with it, now it is a ls/vtec and the fun has just started
Old Sep 9, 2002 | 08:29 PM
Default Re: b16a vs. ls/vtec (CRXSleeper)
a full B16A2 swap is generally about 2500 or so....and the 94+ B18B's are about 2200
Old Sep 9, 2002 | 08:45 PM
DarkSubRosa's Avatar
Default Re: b16a vs. ls/vtec (Unjockable)
I totally dont agree......if built right ls.vtec is reliable, you may not be able to give it the absolute hell you would a b16 or rev it to the moon, but who cares,(its got low end torque, dont need to rev as high) my friend daily drives his B20.vtec and has had no reliability problems. We're turning my B16A into a LS vtec, and I have to have it reliable, and if I felt in any way, shape or form it wasn't then I wouldnt be building it. If done properly with ARP rod bolts and proper other precautions, I say ls.vtec, thats where im headed.
Old Sep 9, 2002 | 08:49 PM
The_Head's Avatar
Default Re: b16a vs. ls/vtec (DarkSubRosa)
Yeah, I would like to know why people say that stuff... I don't think the LS/VTEC concept has been around long enough to prove if it is reliable or not.
BTW, I would go with the B18C. I have a B16A as well and like a previous member said, no ***** under 4000 rpm...
Old Sep 9, 2002 | 09:38 PM
Rydaddy's Avatar
Default Re: b16a vs. ls/vtec (xThexHeadx)
How come no one ever mentions H22a? Its cheaper than b18c anywhere you go, it has better HP/torque figures, etc..? I dont understand why h22a is so often overlooked.
Old Sep 9, 2002 | 09:47 PM
allmtrSI's Avatar
Default Re: b16a vs. ls/vtec (Rydaddy)
i would think because b16's and b18's are easier to get... from what i hear, h22's are hard to come by...
Old Sep 9, 2002 | 10:14 PM
kP_Accord's Avatar
Default Re: b16a vs. ls/vtec (allmtrSI)
i thought h22's were abundant, they jus dont work as well with civics as the b seires does.
Old Sep 9, 2002 | 10:27 PM
blackANESE's Avatar
All this hearsay about lsvtec's. Not one person who bashes one has
ever built one correctly. Do you know anyone with one? Did they build it right?...probably not.
All the horror stories you here are with cheapskates who slap
an lsvtec together and rev the **** out of it.
Don't cheap out. If you take care of it, it will take care of you.
edit*** Also, a lot of people encounter problems if they don't break it in.
correctly
[Modified by blackANESE, 11:28 PM 9/9/2002]
Old Sep 9, 2002 | 10:32 PM
wannab20hatch's Avatar
Default Re: b16a vs. ls/vtec (broke1)
I would go with ls/vtec. Ive only read and heard great things about it. Cant wait to get mine.
Old Sep 9, 2002 | 10:39 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: b16a vs. ls/vtec (wannab20hatch)
an LS/VTEC setup done correctly will be just as reliable as any other. It's a matter of;having someone doing the build that's done it before, using quality parts, breaking it in right, and treating it good.
Old Sep 9, 2002 | 11:02 PM
sirminder's Avatar
i dont think ls/vtec is that bad if built right. i have a b16a right now and ive been thinking of giving that lsvtec a try. but u cant go around cutting corners with it and expect to work like a charm. if u built it correctly + tuned it right + take well care of it = you'll have a monster.
Old Sep 9, 2002 | 11:14 PM
DualKnuttz's Avatar
Banned
Default Re: b16a vs. ls/vtec (sirminder)
I have a well built ls/vtec and it is very reliable. I drive it hard most of the time and its running stronger than ever. It just take a little longer for the revs to get up there but it has a lot of torque. I had a b16a before this and it had no torque. With three people in the car, it felt like it was going to die, but with the ls/vtec it still pulls with three people inside. I say go with ls/vtec but have someone that has done it before to build it for you.
miamiboy91
Jan 28, 2009 04:58 PM
RollieA
Oct 30, 2008 07:54 AM
God-Driven
Jul 11, 2008 04:00 PM
ser13
13
Sep 25, 2007 04:09 PM
wc
May 8, 2003 06:00 PM
