98 accord door problems
Old Apr 5, 2010 | 07:28 PM
evworld's Avatar
TRIAL USER
Default 98 accord door problems
My 98 accord coupe driver side door will not open. It will not open from the inside or outside. The door lock pin lifts to the open position with the auto door opener but I can't get the door open. It is like the door latch is stuck in the locked position or it is broken closed.
I am able too peek inside the door by looking down the window and I can see the door handle moving the mechanism but the door dont open.. Any ideas. I googled and there was a hit on drilling a hole in the door. This was for an older model honda.
Can the dealer get it open?
Old Apr 6, 2010 | 09:13 AM
lordnight's Avatar
Default Re: 98 accord door problems
I think u have a serious problem here. there is 2 way get a slim jim go down in there and pull on linkage. second pull door panel off so u can see what is broke inside..
Old Apr 11, 2010 | 04:22 PM
toofastaccord23's Avatar
same thing happened to me when they broke into my 98 accord, i could not open my door at all, i had to take it to a shop and i had to buy a new relay but im not 100% sure you have the same problem it could be something else just take it to a body shop
Old Jun 14, 2010 | 01:29 PM
tonyasleep's Avatar
Bump........I have this issue, did you get your door open and how did you go about it?
rubenmed
Nov 25, 2012 01:46 AM
JTyson86
Jan 9, 2012 02:11 PM
b18crx
Mar 10, 2008 09:11 PM
Speed_1
Aug 16, 2006 12:03 PM
