WTB: h22 crank
yea it was running strong. i could probably pull the oil pan and send you some more pics if interested. motor is not good for another build but has lots of useful parts on it oil pan, pump, crank, individual pistons etc
Do you have an accurate caliper or micrometer that can measure the main journal size? We're looking for an A4 block, yours doesn't seem to be stamped with that, in the picture, so I'm not sure if it's the right crank.
i got clean h22a crank, rods, and pistons$125, use them and change the bearings u will be ok it will work out
I've got the rods, pistons and brand new ACL bearings. It's the crank I'm missing. We're doing an engine for a customer that blew it up and the crankshaft somehow went missing after we had it repaired. But I need know if the main journal size is over or under 2".
ranta18
15
Mar 23, 2004 06:05 AM
