Suspension & Brakes Theory, alignment, spring rates....
what should i use ?
Old Apr 4, 2010 | 12:59 PM
accord007's Avatar
TRIAL USER
Default what should i use ?
Hi
i'm a new member here and i wanna ask you about something ,,
My ride Is 07 accord 4cyl ..
and i want to drop it .. but i don't know what should i use for that ?
Eibach pro-kit OR ground control coilover ?
which one is more Comfortable on the high-way ? because i drive 300 KM daily to my work location ...
sorry for my bad english ...
Waiting for the Answers....
thanks...
Old Apr 4, 2010 | 02:13 PM
98civdx's Avatar
Master Detailer
Default Re: what should i use ?
eibach for dd for sure. how much are you looking to lower it?
ground controls use eibach springs and are nice because you can adjust it but without aftermarket shocks they wont ride that good, which in my opinon you should replace them either way
Old Apr 5, 2010 | 08:56 AM
accord007's Avatar
TRIAL USER
So you told me to buy eibach springs ...
i'm looking for 1.2 -1.5 in drop ...
are there is any problem if the eibach pro-kit installed with the OEM shocks ??
it will be comfotable or not ?
all what i'm looking for is 1.2-1.5 drop and comforable ride on the High-Way...
Old Apr 5, 2010 | 10:52 AM
98civdx's Avatar
Master Detailer
yes eibach are arguably the best springs on the market.
you would see much better results if you get aftermarket shocks made for a lowerd car but you could use them on stock if you wanted to, depending on the spring, some are acutally made to work with the stock shock.
Old Apr 5, 2010 | 01:04 PM
accord007's Avatar
TRIAL USER
is the eibach made to work with the stock shock?
can you give me a name of a good "shocks made for a lowerd car"
and where can i found it ?
and it will be more comfotable than the stock shock or the same ? ?
thanks
Old Apr 5, 2010 | 02:03 PM
98civdx's Avatar
Master Detailer
Some are, but i dont belive those ones will give you the drop your looking for, call eibach and ask them.
there is kyb agx, tokico illumnia, knoi str-t, and koni yellow.
can get them from ebay, weaksauce, just look around.
on a lowerd car yes, aftermarket is normally better then oem.
Old Apr 5, 2010 | 06:36 PM
Gstowe003's Avatar
What about Skunk 2 springs on OEM shocks? I have a 2003 4 cyl and I want to lower it 2 inches.
Thanks
-G
katoeh2o
Suspension & Brakes
Mar 29, 2011 08:03 AM
Niskyspy
Aug 25, 2007 08:29 PM
The Bster
Feb 7, 2007 02:49 PM
MYSI
24
Apr 5, 2006 08:31 PM
Pav89c
Jan 17, 2006 07:48 AM
