FS/wtt Lots Of Parts
Open to Trades On All Parts
d15b7 rebuilt 0 miles with a6 head and cam head mild new water pump and oil pump 10.5:1 comp$300
willem usb power dual burner $45 shipped
d16z6 high volume fuel rail (dont know brand but inside is way bigger than a aem and other comparing brands) and OBX sheet metal intake manifold (first design) both for $80 shipped
Integra OEm LCA with Good Bushings $35 Shipped
BNIB CRane External coil Kit For obd0 (cap rotor and wire) $20 Shipped
JDM D15b Cam $40 Shipped
ZC 3.888 Final Drive $25 Shipped
D17 Valve Cover $40 Shipped
more to come
SOLD ITEMS
PRB K20 Head Has Cams And Vtec Solenoid $600 Shipped sold
BNIB BC0041 Brian Crower Stage 2 Turbo Cams $350 shipped sold
BNIB BC0040 Brian Crower ValveSprings & Retainers $300 sold
BNIB BC3040/BC3041 Brian Crower SS Valves (8 intake/ 8 exhaust) $200 sold
BNIB CRS5470K3DK20 k20 Eagle Rods $220 shipped sold
D16z6 Head with D17 Valves Springs And Retainers (Stiffer Than Oem)
also with jdm d15b cam and cam gear (the most agressive oem cam)
head has 3 angle valve job ported on both sides polished on exhaust and port matched to skunk2 intake manifold
$250 shipped sold
H22a jdm head with new valve seals installed and crower valve springs $220 shipped sold
bnib d16 oem piston rings 13011-pm6-g02 a set (4 pistons) $70 shipped sold
Zex/ Comp cam 59300 with skunk2 adjustable Cam gear $225 Shipped sold
JDM D15b Crank $60 Shipped sold
Saab Smic (the one with the cast end tanks not plastic) $40 shipped sold
garrett saab t3 .42/.48 50 trim with internal wastegate no smokin very small shaft play doesnt leak and has water lines $170 shipped sold
3" 5bolt down pipe was on d16 but will fit b series also (does not keep a/c) $50 picked up sold
GSR transmission rebuilt with new bearings and synchros 2k ago $550 obo
more to come
SOLD ITEMS
$250 shipped sold
EGRhatch
Oct 23, 2006 01:26 PM
