simple turbo ???? pls
Old Apr 4, 2010 | 04:19 AM
bobbyeg6's Avatar
Default simple turbo ???? pls
witch why dos a hotside vs coldside clock and the compressor spool?
can you install a turbo backwards is that possable?? for it to be installed backwards so that it spools in revers so the turbo dosnt make boost or lifespan is lost?
thanks need to know what kinda of turbo to buy cold or hot side, the one i had was facing the drive side door not trans, witch is?
Old Apr 4, 2010 | 06:15 AM
TheShodan's Avatar
Moderator
Default Re: simple turbo ???? pls
Ok chief slow down. Time for you to do 2 things. 1) Go to HOW STUFF WORKS .com and choose turbocharger. Understand how a turbocharger works. It has lots of diagrams and cross-section photos to follow.
2) Look here
http://www.youtube.com/watch?v=Xp-EV...layer_embedded
and here : (What is A/R?)
https://honda-tech.com/forums/forced-induction-16/why-r-so-important-1023414/
and lastly, here
https://honda-tech.com/forums/forced-induction-16/benefit-higher-whp-%40-lower-psi-1004578/
You'll need to go indepth of all of these articles before you'll get any more kind responses here.
Old Apr 4, 2010 | 01:12 PM
bobbyeg6's Avatar
i know how they work, i might just not be able to get my question out right, i just and to know if the way you clock the turbo on your manifold makes a defference or not because of hotside cold side deal, if you can clock the hotside backwards or vs vers. sry for the mix up i know how they work can have installed them and removed them xtimes.
Old Apr 4, 2010 | 01:18 PM
Kyle R's Avatar
You can clock them in either direction. (I think that's what you're asking?)
Old Apr 5, 2010 | 06:16 PM
bobbyeg6's Avatar
yeah thanks man i was looking at mine tonight an it hit me the compressor blades inside only compress one way dont matter how the air pass by. thanks bro .
Old Apr 5, 2010 | 06:29 PM
madblkscientist's Avatar
WHOA!!!!!!
jdmfreshness121890
Dec 14, 2007 05:38 AM
wernhersey
Jan 25, 2007 07:34 PM
