crx front blinkers dont work
well when i bought my crx the front blinkers and jdm side markers didnt blink. they stay on solid. i looked into the wiring and theres only one bulb in the corner light. i fonud a couple cut wires, but none of them blink with the blinkers. wat color wires are for the blinker bulb? being that none of them flash does that mean my icu is done for? if so wheres it located so i can replace it?
Hope this helps:
https://honda-tech.com/forums/showth...n+signal+wiper
Yeah the flasher relay is in the dash fuse box.
But the cut wires are most likely the culprit. you migth try finding a un-hacked harness at the junkyard to splice in to replace your existing wiring. or find a wiring diagram and re-do it yourself.
i would follow a diagram, but theres 4 wires on each side cut, i tested them with a testlight and NONE of them flash. so if i was to put a new harness on it still wouldnt blink. if it was the blinker relay wuld that make just the fronts not work? becuz my back blinkers work
i would take out a test light and see whats going on with the hacked wires.
are the blinkers blinking faster than they are supposed to? also make sure you have the right bulbs in the right sockets. dont use 1157 bulbs in a single filiment socket.
dont get all mad man. just having a little fun.
