Can a catch can mess with your tune??
Old Apr 3, 2010 | 09:36 AM
SpoolnG2's Avatar
Default Can a catch can mess with your tune??
Ive got a b18c tuned with hondata at 12psi. Ive been running this exact setup and tune for 2 full seasons now without any problems. I just put a catch can system on the car. It consists of 2 -10an lines to the front of the valve cover and 1 -10an line to the back of the block. Everything that was left open was plugged back up. Full throttle seems to be good, however now when i'm cruising the car seems to have some type of engine resistance and then it stops, has resistance and then stops. While this is happening i'm noticing the A/F fluctuating from 13.?? up to 16 or 17.?? . Also, while the car used to idle around 950-1000rpm..it now seems to idle higher too. Can a catch can throw the tune off this much? Has anyone else ever had this happen? Any input would be great, thanks.
Old Apr 3, 2010 | 10:29 AM
96 GSR-T's Avatar
Default Re: Can a catch can mess with your tune??
Adding a catch can setup didnt change my tune that I noticed, if it was to change I would think the WOT might change a hair but cruising shouldnt change at all.
Old Apr 3, 2010 | 10:33 AM
MikeySpec's Avatar
Is it vented atmospheric?
Old Apr 3, 2010 | 12:08 PM
SpoolnG2's Avatar
Yes, it is vented to the atmosphere. All I've done to the car is rebuild the turbo, change the plugs out for new ones (same kind), and put the catch can system on the car. Like I said, its the same tune that's been working fine for 2 seasons. I'm assuming the "resistance" i'm feeling is when it goes lean while cruising?? If its not the catch can then i'm confused as to what it could be. Under full throttle it seems normal and holds right around 11.8:1 like it has been. Fuel pump and injectors are only 2 seasons old. The fuel pressure is still the same as when we tuned it. I'm stumped.
Old Apr 3, 2010 | 12:28 PM
SPOOLINmatt's Avatar
Can Charlie Daniels play a Mean Fiddle?
lol, i cant see how it would affect the tune though.
Old Apr 3, 2010 | 12:35 PM
SpoolnG2's Avatar
Not sure...the reason I ask is bc its the only thing i've changed on the car.
Old Apr 3, 2010 | 12:40 PM
96 GSR-T's Avatar
take the filters off and cap them, if it doesnt go away its obviously not the catch can.
Old Apr 3, 2010 | 12:46 PM
SpoolnG2's Avatar
I thought about that...Just dont have anything to plug the -10 male bungs with.
Old Apr 3, 2010 | 12:57 PM
rip94delsol's Avatar
-10 to -10 male union.
Old Apr 3, 2010 | 01:19 PM
OMG B16's Avatar
Just undo them from the catchcan and loop the hose.
Old Apr 3, 2010 | 02:03 PM
SpoolnG2's Avatar
ok, tried that. Guess its not the catch can. So now i'm definately stumped. I can send someone a datalog of whats happening if they'd like?
Old Apr 3, 2010 | 02:47 PM
RedneckRicer's Avatar
How is your ICM? thats if you are still using a stock one.
Old Apr 3, 2010 | 03:14 PM
SpoolnG2's Avatar
I believe its fine. Like I said above, I dont seem to have any problems or hesitation under full throttle.
Old Apr 3, 2010 | 03:47 PM
i had a similar issue with a ICM especially the resistance issue. felt like the car didnt want to go anymore if i was cruising in 4th or 5th. i tried everything and finally tried a spare dizzy and problem was solved.
Old Apr 4, 2010 | 09:42 AM
locash's Avatar
You say you rebuilt your turbo? You sure a blade isnt contacting the housing now?
Da9austinRacing
Dec 8, 2011 05:52 PM
SpoolnG2
Apr 3, 2010 05:28 PM
shiroitenshi
Engine Management and Tuning
Sep 19, 2008 08:53 AM
Black R
63
Feb 25, 2005 12:19 PM
DUALSTAGE
May 3, 2002 02:41 PM
