**AprilFor Sale/WTB/For Trade Chicago**
WTB acura RSX black leather seats or celica 7th gen black leather seats (2000 and up) front and back prefered celica seats going into my celica thanks!!!
WTB/WTT For:
eg/dc Aftermarket LCA's
15" tires
Turbo Kit (complete with everything)
Gsr oil pan if i get the turbo
Indash Single din or double
Rims
Exhaust or muffler
my fs/ft thread:http://www.hondamarketplace.com/show....php?t=2742869
15" tires
Rims
Exhaust or muffler
I have a GSR transmission that I bought from here a while back but never used. Here's the old thread. I was told that it was good but I can't personally vouch for it as I never installed it. Includes sensors and a mount for an Integra or EG. Just would like what I paid for it - $250.
Also available:
B series linkage and stock shifter from a Civic Si - $100
New in box remanufactured B series axles - $85
B series manual transmission intermediate shaft - $75
New in box generic 4-2-1 stainless steel B series header - $50
Also available:
GM Boost Control Solenoid - Best Offer - Used on a boosted RSX-S
Turbo XS Blow-Off Valve - Best Offer - Taken off a boosted RSX-S
4 - 4 Ply 2.5" Black Silicone Couplers Best offer
1 - 4 Ply 2.5" to 2.0" Black Reducer Best offer
the couplers and reducer are brand new and never used. i accidentally ordered the wrong size for my intercooler piping. these arent cheap ebay couplers so dont lowball me on those please.
I am located close to Golf and Roselle in Schaumburg, IL 60195
fs 92 eg h22a swap 3k obo needs body work http://www.hondamarketplace.com/show....php?t=2739222
91 da shell or u can buy the motors with it n everything to put back together 850 with motors 500 for the shell http://www.hondamarketplace.com/show....php?t=2730614
92 eg front seats 50 bux for the pair (drivers seat ripped in normal spot)
2 stock old skool prelude rims with tires $50
1.94-01 acura integra B18b1 intake no tb bare $50
2.89-92 odb1 b16a intake has one sensor no tb $50- SOLD
3.90-93 acura integra b18a1 intake automatic $50
4.92-95 honda civic eg tail lights stock no cracks no dings $50
5.odb1 chipped p30 ecu tuned to run like a p72 (gsr)
4500rpm vtec, 2 step launch 4500 rpm, red line 9200rpm, shift light 6800rpm $120 SOLD
6.vtec sub harness for cars with no vtec wire hooked up like a eg or a ef , its just the wire to the vtec and the knock sensor, really easy to install - $50 SOLD
7.egay b- series header no downpipe has o2 sensor $20
9.90-93 integra or 92-95 civic power steering pump new $65
10. 2 iacv (idle air control valve) $40 a piece
11. 2 map sensors $20 a piece
12. 92-95 civic eg mirror driver side needs painted already primer $20
14. power steering bracket for b18 $10
15. charcoal box for a integra or civic $20
16. 90-93 acura integra throttle body $40
17. 92-01 civic d16 throttle body $40
18. 89-99 civic d15b throttle body $40
19. new gsr cap $20
20. 90-01 integra b series starter $50 - SOLD
21. b series water pump $45 new
22.heat shield b series $10
23. d16 ac condensor $45
24. b series ac condensor $45
25. b series ac condensor with some lines hooked up $45
26. B SERIES VTEC SOLENOID - $30
92-95 NEWcivic ball joints - $20 a piece
88-91 ef civic rear deck lid - $30
hood latch from a 89-91 si hatchback -$10
have the oil catch beather box for a b18, or b16 motor ("black box")- $25
kenwood cd player 50 bux will update later on the model number... comes connected to a civic harness for a xtra 10 bux
also have 2 96 prelude axles $100 obo brand new in box (oem replacement from advance auto)
98 nissan altima passanger side turn signal oem- $25
19. new gsr cap $20
FS:
EF 3 pod a-pillar thing. brand new. $50 obo
EF front and rear strut tower braces brand new $50 obo
obd0-obd1 conversion harness. $100 obo
DA dizzy best offer
p28 ecu TW/BO
JL audio 500/5 amp. $500 firm
i have more stuff out there. going to get pics and the rest on here later. Thanks. Pm with any questions.
DA dizzy best offer
p28 ecu TW/BO
92 eg with a h22a swap... 3k obo http://www.hondamarketplace.com/show....php?t=2739222
Thermal R&D 2.25" stainless cat back, 92-00 Civic sedan/coupe - $240
OEM Honda cat back, 92-00 Civic sedan/coupe - $80
JDM B20B cylinder head, low mileage, no manifolds, complete valvetrain and valve cover - $100
OEM Honda B20/B18 timing belt and water pump, low mileage, very clean - $100
Buy the B20B head, timing belt, water pump for $180
http://www.hondamarketplace.com/show...php?t=2750446\
Make me a reasonable offer and its yours. gotta sell all this to get my motor. so help a bro out.
Price drop to 4,800 here's the correct picture link
1999 integra gsr http://m970.photobucket.com/albums/s...ptZJpnyJGsw%3D
Cars got 111k and some change
Black on black
Service done
New Timing belt OEM
New water pump OEM
New Plugs
New tires(Dunlop snow and ice tires)
New O2 sensor
Sync oil
New oem air filter.
valve adjustment
Valve cover gasket
Cooling system has been flushed
New upper radiator hose
New power slot rotors
New Hawk HP brake pads
New trans fluid
New passanger side wheel bearing
New alum half core racing radiator
S2000 cooling fan
Currently being added
New oem alternator
New cap n rotor
Wires
Passanger side window motor
Front 02 sensor
Some scratchs and dings here and there
No clear coat fadding, paint shines up
Drivers side qaurter has one inch rust, ive been using touch up paint to make it looks presentable
Blades have some curb rash and some peal
Needs
Shift boot
Shift brezel
HAVC the temp adjust broke so its stuck on hot(Its cold anyways)
AC was taken out because it was going to be a turbo car
Rear bumper could use paint
Head unit is ghetto rigged
Over all a nice daily driver
Im open to whatever, this is just a feeler
http://s970.photobucket.com/albums/a...k1851/Integra/
Black on black
Service done
New Timing belt OEM
New water pump OEM
New Plugs
New O2 sensor
Sync oil
New oem air filter.
valve adjustment
Valve cover gasket
New trans fluid
S2000 cooling fan
New oem alternator
New cap n rotor
Wires
Front 02 sensor
Needs
Shift boot
Shift brezel
Price drop to 4,800
Black on black
Service done
New Timing belt OEM
New water pump OEM
New Plugs
New O2 sensor
Sync oil
New oem air filter
valve adjustment
Valve cover gasket
New trans fluid
S2000 cooling fan
New oem alternator
New cap n rotor
Wires
Front 02 sensor
Needs
Shift boot
Shift brezel
Black on black
Service done
New Timing belt OEM
New water pump OEM
New Plugs
New O2 sensor
Sync oil
New oem air filter
valve adjustment
Valve cover gasket
New trans fluid
S2000 cooling fan
New oem alternator
New cap n rotor
Wires
Front 02 sensor
Needs
Shift boot
Shift brezel
WTB:
92-95 Civic Coupe Driver's Side Door, idk if the hatch door fits
the rest are possibly wtb if the price is right because i can get most of these pretty cheap lol and all for a 92-95 civic coupe
92-95 Civic Coupe Front Bumper (hatch works too)
92-95 Civic Coupe Fenders (both sides, hatch works too)
92-95 Civic Coupe Rear Bumper
92-95 Civic Coupe Trunk
92-95 Civic Coupe Front Windshield
**** I need to get rid of:
*Del Sol Seats - $150 w/ stock rails
*RSX Black Leathers (Rear) - $200
*ITR 5 Lug No rims or Front Calipers - $800 FIRM
*1995 EG sedan...Lowered, Swapped, Sounds, LS Meshies...Need more info? Heres my thread ---> http://hondamarketplace.com/showthread.php?t=2718937
*K20A3 Tranny w/ Linkage, Clutch and Flywheel - $700 OBO
*Front and Rear GSR Disk Brakes w/ Brake Booster, Master Cylinder, and Prop Valve - $450 FIRM and IM NOT PARTING IT OUT!
*2 12" Polk Audio Subs in Box with an MTX Amp...Its in my 4 door and Bumps that Gucci and O.J. Da Juiceman sick as hell!
No trades unless you trade me your cash for my parts or Im in the market for a Raptor of some sort or a Honda TRX quad. Needs to be a 300 or bigger. Thanks. For a faster response hit up the celly 773-457-6828
