Help please. Brakelight and turn signal
Old Apr 2, 2010 | 06:25 PM
slowFTW's Avatar
Default Help please. Brakelight and turn signal
I just recently had to go through the ordeal of changel out the pedal bracket because that little bolt thing supporting the clutch broke on me. I appreciate all the knowledge you guys had posted on this site that helped me step by step.
But now I have another issue. After replacing everything, my turn signals don't work on the dash nor do they work on the outside lights. Also, with my car off my back lights stay on. I have to unplug the battery in order to kill the power to the lights.
Any idea what this could be? I can deal with unplugging the battery for now but I'm kinda iffy about not having a turn signal in such a compact car.
Old Apr 2, 2010 | 06:27 PM
slowFTW's Avatar
Default Re: Help please. Brakelight and turn signal
Also, if it helps, I droppe the steering column to get the bracket out which included unplugging a few wires. Is it possible that I might have crossed the wrong wire?
Old Apr 2, 2010 | 09:11 PM
slowFTW's Avatar
Anyone?
Old Apr 3, 2010 | 07:49 AM
grog's Avatar
This is whats wrong with your brake lights https://honda-tech.com/zerothread/2094313
as for the turn signals have you checked to see if you missed plugging it back in, what about checking your fuses?
Old Apr 4, 2010 | 03:58 AM
slowFTW's Avatar
Ty for your reply. I got the brake light fixed. Lost the plastic price in the hole so I just duck taped 2 pennies over instead for now. :p
I'll check the fuses and wiring for the blinkers. What's weird is the head lights still work on the car. The only thing not working is blinkers and horn. So maybe headligts are on a completely different plug than horn an blinkers?
Old Apr 4, 2010 | 11:59 AM
Sl1ck09's Avatar
this may help check if your hazzards works, if not you mave have unpluged the wire from there causing your signals not to work. i believe you need to have it hooked up to have a compete circuit , correct me if wrong
Old Apr 12, 2010 | 05:44 AM
slowFTW's Avatar
sorry for the long wait for reply. Computer virus :s
but yeah man. That sounds like a logical solution! I wonder
why I didn't think of that. I did disconnect the hazards when I removed the dash and never plugged them back up yet thinking it was no biggy for now.
I will deft check this out on lunch break!
asianalbutt
Feb 20, 2007 12:34 PM
ochdog
Audio / Security / Video
Aug 3, 2005 12:54 PM
kell211
Jun 12, 2005 03:55 PM
ewing86
Sep 30, 2004 05:49 PM
