Suspension & Brakes Theory, alignment, spring rates....
Brakes hanging up after ABS delete
Old Apr 2, 2010 | 11:19 AM
BMo Tuning's Avatar
STAR
Default Brakes hanging up after ABS delete
I recently performed an ABS delete(pump didn't work) on my 1995 integra gsr. I replaced the master cylinder with an RS unit that was bench bled, prop valve was changed to a 40/40 rs unit and lines were fitted. After bleeding the brakes two times they are still hanging up pretty badly. The booster is hooked up properly and there don't appear to be any leaks in vacuum or brakes lines.
I'm going to look over everything tonight and bleed the brakes once more to see of that helps.
Any suggestions/things to check?
TIA!
Old Apr 2, 2010 | 05:06 PM
bleedblue94's Avatar
Default Re: Brakes hanging up after ABS delete
TIA!
did you replace the brake booster with the non abs one as well? if not then that is the probblem bc i made that mistake only to find the abs bb pole os slightly longer then the non abs one, which actually keeps fluid pressurized
Old Apr 4, 2010 | 06:27 AM
Dogginator's Avatar
Daisy... Daisy...
^^^ The RS booster is different. Also, you need to adjust the push rod.
Old Apr 7, 2010 | 05:19 PM
BMo Tuning's Avatar
STAR
That's what I did wrong. I replaced the master cylinder with the RS non abs unit and kept the GSR ABS unit.
I switched out the master cylinders and with the GSR unit back in place the brakes are working properly.
Old Apr 7, 2010 | 05:22 PM
Dogginator's Avatar
Daisy... Daisy...
Check the push rod adjustment to avoid future grief.
Old Apr 8, 2010 | 08:16 AM
this is true or i would suggest just making sure youu always keep the mc and bb together and not mix sets up... saves headaches
87integra
Suspension & Brakes
Nov 7, 2015 10:50 PM
RecklessEJ
Aug 25, 2013 08:13 PM
goldfinger93030
Sep 19, 2010 07:33 PM
juanb
May 1, 2007 03:32 AM
todbld
Dec 19, 2005 05:11 PM
