How to install head unit on a 4th gen. Accord??? Need Help please
Old Sep 9, 2002 | 05:12 PM
JaiDieM's Avatar
Default How to install head unit on a 4th gen. Accord??? Need Help please
I really need help in installing my new sony head unit on my 4th gen Accord...I dont know how to start it..please i need help..
Old Sep 9, 2002 | 08:27 PM
Howitt's Avatar
Default Re: How to install head unit on a 4th gen. Accord??? Need Help please (speedfury2029)
pita lots screws remove the centerconsole, the screws under the ash tray and some near the ac control and in the vents etc, a haynes manual does wonders buy one for a few bones at pepboys
Old Sep 9, 2002 | 08:45 PM
JaiDieM's Avatar
Default Re: How to install head unit on a 4th gen. Accord??? Need Help please (Howitt)
thanks for da help man....I appreciate it....I will pick up that manual 2morrow..
Old Sep 10, 2002 | 08:29 AM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:17 PM 11/17/2006
Old Sep 10, 2002 | 12:45 PM
Ideal's Avatar
Default Re: How to install head unit on a 4th gen. Accord??? Need Help please (schlit)
i just finished doing this about 2 and half weeks ago, remove the plastic molding around your shifter, then remove the ashtray, youll be on your kness, once you remove the ashtray you will see 2 screws where the ashtray was(i think, but i know you will be able to tell) then unscrew those, and boom, you can now take out the head unit.
P.S. when you remove the plastic molding, there are 3 screws on it, one infront by the shifter, one in middle and one in the back, and its on each side, so basically 6 screws, when you pull it off, dont try and unscrew the middle, to make it 2 parts, just pull off the whole thing, but your drivers seat all the way back, and lay it down, so that the resting arm bar doesnt get in the way, put the car in gear 1, if your auto, and pull off the molding
or maybe im just dumb
-jon
Old Sep 10, 2002 | 07:23 PM
JaiDieM's Avatar
Default Re: How to install head unit on a 4th gen. Accord??? Need Help please (Ideal)
thanks 4 da input.....
Old Sep 10, 2002 | 07:30 PM
6GACCORDH22's Avatar
lay in pass. floor board . look up at back of radio . there will be two screws ( phillips) 8mm hex as well . use a 1/4 in. drive w/ 6" extension. you do not have to take console out. i have probably done 100 of them in the past .
92civicx
Acura TL, RL & ZDX
Jan 8, 2009 07:09 PM
TKirk
Oct 8, 2003 11:25 PM
romanzamboni
Aug 2, 2003 07:33 PM
h22congee!
Sep 19, 2002 07:45 PM
LordVtec
Sep 14, 2002 10:10 PM
