Transmission problem/noise
Old Apr 1, 2010 | 06:59 PM
Staypuff578's Avatar
Default Transmission problem/noise
So everyone, i have a big problem. I went for a drive and out of nowhere i couldnt shift into third fourth or fifth. So finally after a couple minutes of cruising it went into third then fourth and kind rammed itself into fifth AND THEN i start hearing this light ticking sound. So i get home and put it on stands and spin a tire (normally the other spins counter clockwise) and the other doesn't spin. I got to the other side and same thing, oh did i mention that ticking sound is there while im doing it. So i spin the wheel backwards and the ticking is worse except theres also like a grinding noise too and the other wheel tries to spin. I'm expecting the worse but hoping for the best. Any help is appreciated, thanks guys.
Btw car is an 88 crx y8 swap/si cable trans
Old Apr 2, 2010 | 12:29 AM
crxxor's Avatar
Default Re: Transmission problem/noise
It sounds like the problem is internal in the transmission, synchromesh or shift fork issues. Perhaps drain the transmission oil into a clean drain pan and see if you have metal filings in the oil that comes out of the gearbox..
Old Apr 2, 2010 | 11:48 AM
thats what i planned on doing.
Old Apr 3, 2010 | 08:53 PM
a&w's Avatar
a&w
TRIAL USER
sound like the diff.
chefcook
Nov 2, 2016 02:06 PM
Deano_d
Honda S2000
Dec 12, 2009 07:16 PM
Jeffrey9
May 10, 2006 05:33 PM
PinoyCivic
Jan 17, 2006 06:03 AM
