2000 Civic SE headlamp Fitment Issues ?
Old Apr 1, 2010 | 03:39 PM
accordingdone's Avatar
Default 2000 Civic SE headlamp Fitment Issues ?
The car is a 2000 4 dr civic SE from Canada, I ordered a headlamp set off of ebay [usa] and this is how its mounting up.
Is this my fault or a bad fitting headlamp ?
Old Apr 1, 2010 | 03:53 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: 2000 Civic SE headlamp Fitment Issues ?
Something is wrong there. I double check the oem Honda parts listings, looks like both 2 and 4 door models use the same part numbers. Not sure what the issue is there.
Question, why buy cheap no name headlights? They are far inferior to actual oem parts.
Old Apr 1, 2010 | 04:23 PM
Really didn't think it would make that much of a difference, Thought that the chrome halo set up was more modern looking as well.
Old Apr 1, 2010 | 05:20 PM
98civdx's Avatar
Master Detailer
Wow, i have ebay headlights and they arent nearly this bad. What i think of is put the headlight stay back on and mod the headlight mount and you should be able to close up that gap
Old Apr 1, 2010 | 07:59 PM
Anon51's Avatar
i'm thinking you bought the wrong headlight. not sure what the 2000 civic se equivalant is in the us. but it may have similar body lines to that of the 96-98 civic headlights.
Old Apr 1, 2010 | 08:45 PM
http://cgi.ebay.com/ebaymotors/ws/eB...1104&viewitem=
This was the ebay auction.
98civicdx:
You cant even make this headlamp work.
Its just not possible.
Old Apr 2, 2010 | 01:30 PM
98civdx's Avatar
Master Detailer
i said the same thing with mine, and trust me a few minutes with a dremil got it pretty good, they look like *** when you pop the hood but the line up better.
take the bolts off and push the headlight into the position it should be in and look at how far the bolts are off, it can be done
Old Apr 2, 2010 | 02:41 PM
NOFX's Avatar
H-T White Ops
The Civic SE sedan is also a US model. It's also called the VP (Value Package) or DX-V.
'99-'00 headlights are the same on all coupes, hatches and sedans in the US and Canada. I've never heard of any '99-'00 front end fitting differently than any other '99-'00 front end. '96-'98 front ends LOOK different. See the corner of that headlight and where it meets the fender? Those parts look different on '96-'98 Civics.
The only thing I could think of it that it's hitting something behind the light.
Could you take a photo of how it fits behind the headlight?
Even aftermarket lights shouldn't fit this poorly.
Old Apr 2, 2010 | 05:48 PM
canadaek's Avatar
um has the car been hit ? look's like the corner of the bumper suport is bent in. and if you don't mide how much did it cost you to have them shipped to canada?
Old Apr 2, 2010 | 06:15 PM
yea it was hit, But just the front bumper cover was damaged.
and I didnt have it shipped anywhere, Its originally from Canada someone either had it imported here or they drove it from Canada to the states.
But It def was made in Canada, On the door sticker it says "Honda of Canada"
98civdx & NOFX: You guys hit on the head..It was hitting the fender to frame brace..So i'll have to delete that to make it work, as well as not using the OEM mounting holes.If I push the headlamps back it goes beyond where they need to be to use them. So looks like I'll be doing to cutting and Drill/Tapping.
Old Apr 2, 2010 | 06:20 PM
98civdx's Avatar
Master Detailer
i drawing up a blank here trying to figure out exactly that is lol, been a while sence i pulled my head light, could you snap a pic of it?
if it were id just push it back untill i like it a drill the mount on the housing it self not the core suport.
rawrjaay
May 4, 2016 08:54 AM
vndsd1
Nov 13, 2009 03:26 PM
GsrBrideteg
Sep 3, 2007 09:13 PM
