? about 89-91 crx si
It should bolt in... I was going to use it beacue I wanted the integra steering rack for power steering and it has a better steering ratio.. but it might need a little minor work.. give it a shot
There was a guy(From Yokohama,JP) that was saying that is car EF-8 came with the same subframe as our G2.
But,our car (USDM) as not the same bolt pattern(2 bolts won't line up with the hole).
So I guess you should forget that idea,unless you want to get some work to be done.
looxs
Apr 4, 2006 12:33 AM
classciv
Mar 28, 2006 02:09 PM
