Correcting ATTS problem.
Old Apr 1, 2010 | 10:13 AM
Tunerguy1989's Avatar
Default Correcting ATTS problem.
I have had my ATTS light on for a while now and I Check the code and it turned out to be code 62 which is the left oil pressure sensor. Would replacing the sensor fix the problem or could the whole system be shot? I no there is not much information on the ATTS and its a real pain in the *** but I just want fix it rather than looking into a new transmission or a base swap or is it not worth it?
Any input would be appreciated.
Old Apr 1, 2010 | 11:16 AM
red92si's Avatar
Default Re: Correcting ATTS problem.
Replace the faulty sensor. Reset, and then check to see if the code is gone. Then you'll know.
Old Apr 1, 2010 | 11:19 AM
have you ever worked on an ATTS system. Do I have to drop the motor to get to the sensor or is there any way to replace it without taking the whole atts system out?
Old Apr 1, 2010 | 12:10 PM
integra15's Avatar
Either the helps manual or the Honda supplemental atts service manual will probably have that answer.
Old Apr 1, 2010 | 03:21 PM
Kronn 98SH's Avatar
Replacing the sensor will most likely fix the problem and it can be done without dropping the system. I had to do this once before. However, it is very much a pain in the ***.
Also, a new sensor is about $250 from Honda (or $175 online). So try to find a used one like I did.
CPEF9
Sep 11, 2016 02:45 PM
Willie27812
Jun 19, 2011 02:14 PM
Carbcivic
Apr 2, 2008 03:28 PM
