** April FS Sticky **
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 1-1-2010, any edit to these threads, will result in sanctions. if it persists, the stickies will disappear for good.
4) NO WTB ADS!
Selling for a friend. Contact me for more info. All parts can be shipped at buyers expense.
p72 gsr missisauga engines ported head that was on sergio lisboas h/r car that went 8.7@172 head includes ferrea roller rocker setup/ferrea 1mm oversized valves/ ferrea ti retainers/ eibach valve springs head has exhaut ports coated with high heat coating. head is also dilled for .630 studs,also comes with correct cometic head gasket for it.
$2500 obo
custom sheetmetal intake manifold comes with twin fuel rails, t/b flange is setup for 105mm mustang t/b, made with 4 velocity stacks inside, was also on lisboas h/r car before he parted it out,
$750 obo
95mm holley mustang carb, comes with tps and also the shaft that holds the plate was redone stronger, as they are weak from holley, like new
250$ obo
integra 94-01 Full-race top mount twin scroll dual wastegate header almost like new $800obo will include 4inch downpipe with it for extra 100$
aem 30-1050ems comes in the box with cable
750$obo
$2500 obo
$750 obo
250$ obo
750$obo
Call, Text, Email or send a messenger to Delaware
Cell: 302-312-1533
Email: TurbodGSR96@aol.com
B-Series P72 Cylinder Head: Ported/Polished, Decked .010", Pressure Tested and stuffed with $1200 worth of Ferrea Valvetrain (Ferrea Ti Retainers, Spring Seats, Locks, new seals, 5mm Oversize Super Alloy Valves and 100lb seat pressure Dual Turbo Valvesprings) (will include clean JDM GSR Cams/Stock Cam Gears and a Valvecover). I put 3,000 miles on this head (the first 1500 were NA, the last 1500 boosted most of them were to work and back, made about4 passes at the track) and it made power to 9800rpm before leveling off with GSR Cams on the dyno, I have over $2300 invested in this head and I will let it go for $1250+ shipping
Stock GSR Rods: Came out of a Clean stock JDM GSR Motor: Make me an offer
DC Integra Fenders and Hood: In great shape no dents, primed and ready for paint: $100 ea or $250 for all of it Pass Fender and Hood SOLD
S&W Racecars Custom 8pt Cromoly Roll Cage for a DC/EG/EK/EF: Complete nothing is missing, I have the 6x6 1/8" MS plates for the floorboards as well. Includes the added X for the rear bars and an additional 8' of moly to do whatever with Paid $500 over for it, I will let go for $400 firm
ACT Streetlite Flywheel: 3,000 Miles SOLD
Edelbrock VictorX for a GSR: Powder Coated Gloss Black, Edlebrock logo has been sanded and polished. TB Opening has been bored to 70mm and I had the head flange milled so it was nice and flat. SOLD
P72 Cylinder Head off JDM GSR: Good Condition, came off an H-Motors swap that I bought off a friend, I am using the block for my new sleeved engine. No issues that I know of, mileage unknown. will include VTEC Solenoid and Waterneck and everything else except dizzy and intake manny. $SOLD.
GSR Crankshaft: Came out of a Clean stock JDM GSR Motor, no spun bearings no issues: SOLD.
Crower Pro Billet Rods for a GSR: These are the real deal I paid over $700 for them selling for SOLDthey are used but in perfect condition.
Ball Bearing T04Z (aka T04R, GT37R, T3/T67ho,T4/T67 etc)
1 pass down the track, no dyno time, no chips or dirt on the wheels, no shaft play.
I will include both the used T3 .82 A/R 4-bolt GT Turbine Housing and the new T4 .96 A/R 3" GT V-Band Turbine Housing AND both a Non-polished Cast "S" Compressor Cover and a Polished "S" Cover.
This turbo cost me $1,660.00 + shipping from http://www.atpturbo.com/mm5/merchant...Category_Code=
The first person to come up with SOLDwith all the housings included and I will throw in the Oil Restrictor, -6an coolant fittings for the center section and a Billet Return Flange w/ -10an Fitting.
Cell: 302-312-1533
$450 Prologger Wideband/Boost datalogger and controller (new)
Wires are terminated to the terminal strip and unit was mounted via velcro.
$50 Flaming River battery cut switch
The best battery cutoff out there. Period.
$550 AFI Intercooler 24x12x3.5 garrett core (basically new)
Setup for wiggins clamps, but regular hose and clamps work too.
$475 (ONE) Weld Racing one piece 15x3.5 skinny - polished (new)
$475 (ONE) Weld Racing one piece 15x3.5 skinny - gold (new)
$100 BDL Camgears (pair)
I WILL UPDATE THIS THREAD WITH MORE ITEMS DAILY
I ran into a money situation. I need to sell some things to try and make some cash back.
EVERYTHING IS BRAND NEW, NEVER USED
B16a2 head fresh from the machine shop -$650
new valveguides and seals
omni dual valvesprings
3 angle valvejob
lightly resurfaced
gsr cams included
NOT INCLUDED..valvecover, dist, intake manifold
Custom Web Cam 260 duration @ .050 with .485 lift Turbo Profile - $600
Chase Bays Custom MIL-SPEC harness...it consist of dual mil-spec connectors (one for the main engine harness and the other for my m&w pro-10/crane cams coil ignition set up), T1 cam trigger, duesch (sp?) connector for the dist, Injector dynamic injector clips (special type of plug to run the ID Bosch 1000cc inj), also, the boost solenoid is integrated into the harness.
This Package will come with harness itself ($1,400), M&W pro10($475), Crane Cam PS92($99), T1 cam trigger with both GE cam gears($600), Boost solenoid and T1 bracket($100), dist w/ msd cap ($100), and groud wires. AEM EMS IS NOT INCLUDED. everything roughly comes to $2,800
asking $2,350.00
B16A hydro transmission..freshly rebuilt (new bearings, synchros 3/4 gear) Quaife LSD - $1,700
Fuelab FPR... comes with chrome mounting plate..fitting not included - $130
ONE FAB SR20DET turbo manifold..needs to be finished welding..two 1 inch long areas on opposite sides of mani - $300
Chase Bays Booster Delete w/ Wilwood MC..all polished - $275
-10an hose ends and 10ft of hose - $200
valve cover with 2 -10an bung and the cam gear cover completely cut off - $120
powder coated domant purple vc with 2 -10an bungs..one is stripped - $120
60mm Defi boost gauge.
Reads PSI and lights up amber. Comes with control until and a mounting pod- $250.
1993 civic hatch
Fully painted inside/outside sebring silver off s2000
All new moldings/ caps/bolts/ etc
Apexi n1 99 spec susp
Subframe, lca, rear engine T bracket powder coated extreme chrome
Walbro intank wired with direct 12v
-8an line ran from the tank to the engine bay
Gsr brakes front/rear with braided lines
All brakes lines have been tucked to the cabin side of the firewall
Benen tie bar and function7 lca’s
Spoon replica mirrors
Dss stage 2.9 axles with hub..extended arp studs all around (b-series)
GSR fat fives with decent tires included
NO seats
here is the build thread for the car https://honda-tech.com/forums/appearance-build-threads-122/vietjdmbois-eg-hatch-build-thread-2212864/
ASKING PRICE - PRICE DROPPED $4,500.00
SOLD ITEMS
BMC Race T4 Ramhorn, Polydyn Ceramic Coated, 44mm wg flange, fully polished 4'' aluminum dp, full stainless dumptube - SOLD
BW S366 ett T4 flange, Polydyn coated exhaust housing, powder coated comp housing, chromed brackets - SOLD
Fluidyne Radiator..comes with alum shroud and fan. all pieces FULLY POLISHED, comes with -16AN bungs welded on -SOLD!
Hargett 3'' Clamps - SOLD!
GE fuel rail..b-series..black - SOLD!
Full-Race Pro-am Traction bar for eg/dc.. actual bar has been chromed. will include all hardware and bars. - SOLD
Innovative Solid Mounts for eg/dc..fully polished - SOLD
Nardi steering wheel, splash hub (eg/dc), nrg quick release - SOLD
Omni B-series 4 bar map sensor. Brand new -SOLD
Push-lock fittings and 6ft of hose - SOLD
Jegs Coolant overflow tank..fully polished - SOLD
Garrett 24x12x3.5" IC core - SOLD
Modified by vietjdmboi at 12:07 PM 4/18/2010
3 angle valvejob
lightly resurfaced
gsr cams included
asking $2,350.00
1993 civic hatch
NO seats
SOLD ITEMS
Brand New borg warner/Bullseye Power S372R for sale.
1.10a/r turbine housing
new Race cover with the v-band option
comes with brand new stainless downpipe flange and clamp
comes with brand new aluminum compressor cover outlet and clamp
Asking $1400. I'm losing money on this.
pics:
pics:
THIS CAR IS SUPER LIGHT!
CRX drag car, 1991 with three K motors, tranny and tons of parts.
(motors are stock, one is complete and running, two are disassembled complete missing one head) Motor and trans and clutch is in the car.
Fiberglass one piece front clip, doors, and rear hatch.
Almost all new and way too many to list. Car has NHRA certified chro-moly cage.
New paint, Lexan, New Lexan, 2 brand new clutches including one high doller , trans with spool, fuel cell, Hasport mounts, axles, more more more.
All welding and fab work done and painted. Feul cell mounts, battery mount, interior tin work, everything fabbed and painted.
Not running, needs wiring and header and ECU.
http://s976.photobucket.com/albums/ae248/scottlucky/
Was $4300.00 ---------NOW $3900.00 !!!
Call 714 342-6485
Located in Orange county, not far from Disneyland.
Call 714 342-6485
What's up. I have a 06 z1 tranny for sale with a **** hair over 41k. Im going boost now so i have me a 5 speed Ep3 tranny. NO GRINDS at alllll! Asking 800$
Pm or text me for more details 914 557 9048
Prefer local pickup or I will ship at ur cost
Will trade for a CC twin disk
92 CIVIC COUPE, LS VTEC, JG PRO SERIES HEAD, JG EDLEBROCK INTAKE W/RPM THROTTLE BODY, 1600 INJECTORS, DFI ENGIE MANAGEMENT W/MSD DIGITAL 6 W/2 STEP, GARRET TURBO, FULL CHROMALLY CERT CAGE TO 8:50, REAR SUSP CHANGED TO (RON LUMAS) STRANGE STRUTS W/SPINDLE MOUNT BOGARTS, 15 IN WELDS ON FRONT, DRIVE SHAFT SHOP AXLES, PRO DRIVE SPOOL, FULL INTERIOR SHEET METAL, FIBERGLASS DOORS, FRT END, DASH AND TRUNK LID, CUSTOM PAINT AND AIR BRUSH, F.A.L LEXAN WINDOWS, WHEELIE BAR AND CHUTE. LOTS TO LIST. CAR RUNS CONSISTANT 10:40 AND IS TURN KEY, POSS TRADES, SERIOUS INQUIRES PLEASE.
B16 -stock head taped for Ls/vtec --------> 350.00
precision 825 hp intercooler-------------> 300.00
Type R cams------------------------------->350.00
BDL cam gears------------------------------>150.00
JG polished intake manifold b16----------->300.00
sparco evo seat----------------------------> 400.00
sparco speed seat------------------------> 150
shipping is not included in any of these prices.
Please pm me for pictures! Must sell everything by the end of the week.
shipping is not included in any of these prices.Please pm me for pictures! Must sell everything by the end of the week.
Garrett 4088R DBB T4 .92AR(i think somewhere around there can find out if interested.
A few dyno runs on it its brand new blades are pefect and will spin for 5 min after you shut the car down.
$700 shipped anywhere in the 48
HELLO
i have a Haltech e6s-8 ecu for sale ,
works great,
includes a NEW long harness,
also comes with manual and serial cable.
looking for 450 shipped, or trade for somthing. i dunno
thanks
works great,
thanks
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
i was going to put a k series in my 99 si and i have change my plans. all the parts i have are new in the box. for fasted response you can call or text 240-217-0647
ekk2 mount kit.. $475
karcepts shifter kit $100
karcepts rbc manifold adapter kit missing gaskets tho. $30
hybrid 99-00 civic pnp harness.300
karcepts iacv block off $20
black with 6 and fittings. $100
exo speed front 675 obo. pickup only
