2001 Honda Accord EXV6 - Creaking Noise When Braking at Very Low Speeds
Old Mar 31, 2010 | 07:27 PM
JoeSchmoe's Avatar
TRIAL USER
Default 2001 Honda Accord EXV6 - Creaking Noise When Braking at Very Low Speeds
2001 Honda Accord EX V6. About 137000 kms. I am hearing a creaking noise occasionally when I am braking at very low speeds - like almost when I'm stopped. It's a rhytmic type of noise coming from the rear of the car. At best I would describe it as a mix between creaking and scraping. Kind of sounds like a heavy chunk of metal rubbing against something rhytmically as the wheel turns. Brake Pads and Rotors are all less than 1 year old. The same shop that installed them just inspected everything (pads, rotors, calipers) and said they don't see anything. They also changed the calipers about a year ago. The noises actually disappeared after that for almost a year until recently. They don't hear anything either because it only seems to come once in a while and usually only after driving for while. I never hear it in the morning - usually just when I'm getting back home in the evening. It's very frustrating because any time I take it in they say they can't hear it but then later in the day ... there it is when no mechanic is around. Please Help!!!
Old Apr 1, 2010 | 08:28 AM
nhldogg's Avatar
Default Re: 2001 Honda Accord EXV6 - Creaking Noise When Braking at Very Low Speeds
Your roters may be warped. If they are warped you will hear a lot of noise.
brijsingh
Aug 6, 2011 10:17 AM
elad68
Nov 21, 2009 04:20 AM
Landshark68
Apr 20, 2007 10:01 AM
JMcGovern60
May 23, 2005 12:58 PM
doowop22
May 23, 2004 01:54 PM
