Outside temp affecting idle?
Old Mar 31, 2010 | 06:39 PM
kcxtremeaccord's Avatar
Icon6 Outside temp affecting idle?
Ok so im really confused. Here in wonderful Kansas we are at that tiem of year when mother nature plays tricks with the weather and it goes form hot to cold every day. Now all winter my car has started and ran perfect. Warmed up and then idled at 7-800 rpm. Now however when it reaches over 50 degrees outside, after the car warms up it will not idle down. In fact the longer i drive it the higher the revs go and stay when in neutral. Can someone suggest where i should start. Thanks Kenny also its a 95 EX with CAI,H,E
Old Mar 31, 2010 | 06:47 PM
Elvis1977's Avatar
Default Re: Outside temp affecting idle?
Check your idle control valve. It may need to be replaced. What is the mileage?
Old Mar 31, 2010 | 08:23 PM
quickster's Avatar
idle control valve needs to be tested.
Old Mar 31, 2010 | 09:13 PM
nicolaselias's Avatar
Loved
Community Favorite
Could an idle control valve also have the reverse effect of allowing your idle revs to drop too low? to say 650 or 700?
Old Apr 1, 2010 | 04:39 AM
Mileage is 180,000. How would you check and test it. I know what and where it is but how would you test it to see if its bad.
TearSDMF89dx
Jan 3, 2012 04:31 AM
Junkyard2000
Oct 26, 2005 03:16 PM
bxsi
Jun 1, 2003 05:56 PM
PorscheGT2
Feb 8, 2002 03:36 AM
