honda hx wheels
Old Mar 31, 2010 | 03:50 PM
ac26's Avatar
Default honda hx wheels
got a 89 honda crx and put honda hx wheels on my car and the front caliper hits the rim anybody else have this problem..any suggestions???
Old Mar 31, 2010 | 04:02 PM
EFRue57's Avatar
Default Re: honda hx wheels
are you sure they aren't the 13" vx wheels?? they look almost identical. are they 13" or 14"? the hx's (14") should clear with no problem as many people have these wheels on their ef's.
Old Mar 31, 2010 | 04:15 PM
ac26's Avatar
they are defintely hx and 14's...i don't know if the calipers are stock maybe they are integras not sure.i'm just gonna grind the caliper a little i guess
Old Mar 31, 2010 | 05:48 PM
decev's Avatar
TRIAL USER
in for pics of the modded caliper
Old Mar 31, 2010 | 06:54 PM
you_so_fah_nee's Avatar
TRIAL USER
If they are the HX assuming you're running stock brake/caliper, you'll have a 3/4 inch clearance or more.
Old Mar 31, 2010 | 07:28 PM
dannysolis92005's Avatar
you might have the lagers caliper from the integras or from the ef sedan ex. the larger calipers where made by nissin. so check if your caliper says that. its easy to tell the apart!
Old Mar 31, 2010 | 07:31 PM
crx_si-r's Avatar
dont grind your caliper. just get some spacers.
hx and vx rims will clear stock calipers.
Old Apr 1, 2010 | 02:19 AM
EFRue57's Avatar
also, are you 100% sure it's the caliper that is grinding against the wheel? Have you taken the wheel off to see if there are marks either on he caliper or on the inside of the wheel itself? could it be your brake pads that are worn down past the squealers and are now grinding against the rotor?
Old Apr 1, 2010 | 04:41 AM
Nickstadx's Avatar
sounds like you have the Da BIG brake upgrade which means you dont have to grind down the caliper just the mounting bracket for the caliper. easy easy fix. dosent hurt the calipers at all.
Old Apr 1, 2010 | 05:21 AM
Aftermath_Hatch's Avatar
Had the same problem on an old parts crx i had about 5 years ago,but can't remember how i fixed it...
Old Apr 1, 2010 | 07:04 AM
crx_si-r's Avatar
i had to grind down the caliper bracket as well when i mounted my HX's on my EJ8. solved the problem right away. but now i regret it and should have gone with some spacers instead. just my personal preference is all.
Old Apr 1, 2010 | 09:29 AM
Charlie Moua's Avatar
hum.... werid.
On my ef hb si and hx they cleared my stock brakes fine.
with ITR calipers on stock knuckle and 10.3" rotors I had get a spacer big time.... but if you look at the caliper size between dx & ITR it's like looking at a B vs H sereis... noticablly way bigger.
Old Apr 1, 2010 | 11:50 AM
enrique_kix's Avatar
TRIAL USER
you need to buy spacers i had the same problem.. you can buy the spacers at any pepboys.. trust thats what u need, 4 lug spacers..
Old Apr 3, 2010 | 05:18 PM
ac26's Avatar
i just grinded it down like an 1/8 of an inch or so,thanks for the help everyone
Old Apr 3, 2010 | 05:38 PM
90_EX_Civic's Avatar
was about to say check the sig.
Old Apr 3, 2010 | 06:22 PM
saltypants's Avatar
Interesting thread. I'm glad I saw this as I have recently been trying to hunt down a set of HX wheels for a stock 1991 Si hatchback that I picked up last week.
So am I reading this correctly? These will NOT fit on a stock Si, whether it be a CRX or Civic, without grinding or spacers?
Dc2 Joe
Jan 13, 2006 12:38 PM
Hulk_EJ8
Jan 11, 2006 10:05 PM
4drferio
11
Nov 1, 2004 08:52 AM
dom93hatch
Aug 7, 2002 08:08 PM
