Value of t3/t4 that needs a new turbine wheel?
Old Mar 31, 2010 | 11:50 AM
b18c1wes's Avatar
Default Value of t3/t4 that needs a new turbine wheel?
Just as the post says I have a t3/t4 57trim .63 a/r that has been sitting for a couple years. I pulled the turbo to replace it with a smaller turbo for better spool. I should mention that I was only running 8psi at the time and the turbo was boosting well.
Old Mar 31, 2010 | 05:56 PM
Mr.Spec's Avatar
Default Re: Value of t3/t4 that needs a new turbine wheel?
value is zero .. you cannot just change the turbine wheel. its connected to the shaft. once you go through the motions of rebuilding it. its cheaper or not too far off from just purchasing a new turbo.
Old Mar 31, 2010 | 06:00 PM
YARO.'s Avatar
+1^
Old Mar 31, 2010 | 06:26 PM
b18c1wes's Avatar
So I should toss it in the trash or are the housings worth anything?
Old Mar 31, 2010 | 06:46 PM
TheShodan's Avatar
Moderator
No, he's just saying its maybe worth 50 to 100 dollars without repair. Turbine wheel/shafts are over 200 dollars for the part and easily another 300 in repairs.
Old Mar 31, 2010 | 07:01 PM
Mr.Spec's Avatar
its worth something .. to someone .. for housings .. for mock up turbos. or maybe a HMT guy that just doesn't care
FeelTheBass
Dec 23, 2014 04:26 PM
B18B_EJ1
Jun 5, 2011 06:54 PM
typer604
Mar 28, 2009 10:16 AM
Honda Sport
Jul 16, 2004 04:58 PM
delslow94
Jul 29, 2003 02:50 PM
