How To? Cam-Positioning Sensor! Please assist. (PIC's)
Old Mar 31, 2010 | 11:11 AM
JDM3JDude's Avatar
Icon6 How To? Cam-Positioning Sensor! Please assist. (PIC's)
Hi Name is Anthony..
I drive a 2002 Honda Civic Si.
My car thru a code for my Cam Positioning Sensor.
I have the Sensor, But i dont not know how to proporly install the part.
If anyone can send or direct me to a diagram on How To.!
It would be highly appreciated..
Old Mar 31, 2010 | 11:12 AM
JDM3JDude's Avatar
Default Re: How To? Cam-Positioning Sensor! Please assist. (PIC's)
here are pic's after I located the sensor. but i have recently realized this motor has two sensors.
the code thru bank1. but which one would be one ?
Last edited by JDM3JDude; Mar 31, 2010 at 11:13 AM. Reason: better source of link for my picture's.
Old Mar 31, 2010 | 12:30 PM
theineffable's Avatar
both sensors are probably identical. you can swap one, and if it doesn't fix the problem, swap the sensor to the second location. if that still doesn't work, you might have bigger problems (ie. camshaft that's walking?)
Old Mar 31, 2010 | 12:35 PM
also, do you have a multimeter? on my s2000, the sensors were just magnetic switches (contacts open or closes as it gets near metal).
if you want to manually test the sensors with a multimeter:
1) put the leads across the sensor terminals
2) put the meter in ohms mode
3) monitor continuity as you place the sensor near metal. (does continuity change as you bring the sensor near a piece of steel?)
Old Mar 31, 2010 | 02:44 PM
JDM3JDude's Avatar
Icon3 Re: How To? Cam-Positioning Sensor! Please assist. (PIC's)
I am gonna go give it a shot now. BRB
gitarman2
Apr 30, 2013 06:05 PM
efyou999
May 24, 2012 12:21 AM
Rockford2000
Jan 21, 2006 05:51 PM
jpangeles
Sep 12, 2004 05:23 PM
