1" to 15/16 adaptor-master cylinder problem
Old Mar 31, 2010 | 05:45 AM
hammeredgsr's Avatar
Default 1" to 15/16 adaptor-master cylinder problem
Hi guys! quick question for you guys. I recently converted my ef to rear disk off a DA integra. I found someone sellin a 1" master cylinder that would work with my car so i put it on with the rear disk conversion. The master cylinder went bad soo now i dont know where to get the 1"master cylinder that doesnt need ABS? soo i bought a 15/16, but i forgot when i changed the original master cylinder i had to change the fitting on the line closest to the fire wall, because the fitting is larger.....Now im lost in what to do because i dont know what the 1" master cylinder came off as it didnt run on ABS so i cant just go and buy it. I would like to know where i can get a 1"master cylinder that doesnt run on ABS before i try getting a 15/16 and if i do go the 15/16 route can anybody tell me if autozone or advance auto sells something like an adaptor from a 1in master cylinder to a 15/16? all the help is appreciated!!
Old Apr 1, 2010 | 04:39 AM
Default Re: 1" to 15/16 adaptor-master cylinder problem
come on people help me out
Old Apr 1, 2010 | 05:58 AM
CRX Toad's Avatar
From what I understand all 1" came on ABS. You just need to go to the parts store and get exactly what you had.
Old Apr 1, 2010 | 06:48 AM
4drEF's Avatar
Keyboard Humorist
Running an ABS MC in a non-ABS system is perfectly fine.
Old Apr 1, 2010 | 11:49 AM
ok ima try a abs mc from a DA ill let u know how it goes guys thanks!
Old Apr 1, 2010 | 01:05 PM
4drEF's Avatar
Keyboard Humorist
Assuming you have a DA booster now?
Old Apr 1, 2010 | 04:20 PM
CRX Toad's Avatar
I have a DA ABS booster and MC on my car now. The booster says 290v the non-abs say 260v. You can only put ABS booster with ABS MC. You CANNOT CANNOT CANNOT put non-abs booster with ABS MC or vise versa.
Old Apr 1, 2010 | 04:43 PM
Tyson's Avatar
what doe the MC have to do with the ABS? ive never known there to be a difference.
but not like ive ever looked into it either.... so im asking for real.
hyabusa hunter
Oct 3, 2010 04:19 PM
hammeredgsr
Suspension & Brakes
Apr 2, 2010 11:35 AM
ef9robert
Jul 28, 2008 04:53 PM
9112
Nov 30, 2007 07:29 AM
CroSi
Jan 29, 2007 08:18 PM
