1" to 15/16 adaptor?
Hi guys! quick question for you guys. I recently converted my ef to rear disk off a DA integra. I found someone sellin a 1" master cylinder that would work with my car so i put it on with the rear disk conversion. The master cylinder went bad soo now i dont know where to get the 1"master cylinder that doesnt need ABS? soo i bought a 15/16, but i forgot when i changed the original master cylinder i had to change the fitting on the line closest to the fire wall, because the fitting is larger.....Now im lost in what to do because i dont know what the 1" master cylinder came off as it didnt run on ABS so i cant just go and buy it. I would like to know where i can get a 1"master cylinder that doesnt run on ABS before i try getting a 15/16 and if i do go the 15/16 route can anybody tell me if autozone or advance auto sells something like an adaptor from a 1in master cylinder to a 15/16? all the help is appreciated!!
i think the link below will answer your questions:
https://honda-tech.com/forums/suspension-brakes-54/da-booster-master-cylinder-ef-2570678/
also, a 90-91 civic EX 15/16" master cylinder will bolt on to your 88-91 civic/crx EF's brake booster
hammeredgsr
Apr 1, 2010 04:43 PM
#Leo#
Mar 15, 2009 07:57 AM
