Hi Flow cat
Old Mar 30, 2010 | 07:29 PM
eDizzle's Avatar
Icon3 Hi Flow cat
my oem cat is going bad on my 2000si because i smell it... and it makes my CEL come on every once n a while(i just reset it and it stays of for long time).. if i buy a hiflow will it b ok and not give me a code?. or should i order a another oem cat? if so can u guys help me out with what kind i could get and link me were to get it at?
anyone have any experience with a hiflow cat?
any help would be great
thnx
Old Mar 31, 2010 | 05:43 PM
eDizzle's Avatar
Default Re: Hi Flow cat
oem cat going bad....what should i do? anyone?
Old Mar 31, 2010 | 06:15 PM
leakysi's Avatar
go to a good exhaust shop and have them weld in a new cat, the oem one from a dealer runs north of 1000
The hi flow cat is probably just a test pipe, and you will get a cel unless you do a bypass or something
Old Mar 31, 2010 | 06:53 PM
Korman's Avatar
Magnaflow makes high-flow cats. They probably really aren't that much better then OEM, but they're like $100. It's definately cheaper then most and, who knows, I might be wrong and they are a lot better.
Last edited by Korman; Mar 31, 2010 at 06:53 PM. Reason: I can't spelll *and* apparently.
Old Mar 31, 2010 | 07:07 PM
redexcoupe's Avatar
I have a magnaflow highflow cat, my oem cat was clogged up! NO CEL so id say go with it!
Old Apr 1, 2010 | 05:51 AM
eDizzle's Avatar
im going to search it now... is it a universal cat? i have a dc header and dc full exhaust.. bolts up? sorry to sound so ignorant but i dont know anything about catalytics
Old Apr 1, 2010 | 06:46 AM
redexcoupe's Avatar
Well magnaflow makes a universal one, but it has to be welded in place its like 80 bucks.
Or they make a direct fit one, which is what i bought for like 130. And it just bolts up in the stock location. It should bolt right up to your exhaust system, if you still have the OEM one on your car, the magnaflow cat should fit no problem!
Old Apr 1, 2010 | 06:49 AM
iRIDElow's Avatar
does anyone have a link were i can find the magnaflow one that bolts in (not the universal) i have same thing 99 si and im intersted in checking one of these out
Old Apr 1, 2010 | 06:57 AM
TurboTron's Avatar
just get a hi flow cat with the "bung" on it for your O2 sensor...the "smell" you are having usually means that a cat is working
Old Apr 1, 2010 | 07:05 AM
B16AGUY's Avatar
Whatever you do stay the heck away from "Vibrant" hi-flow cats.
They are cheap and they suck... I had one clog and unburnt fuel collected in the chamber and detonated blowing a nice hole in the cat and getting bits of the the cat's guts caught up inside my exhaust. When you call them about the warrantee they pretty much tell you to F-off.
Old Apr 1, 2010 | 07:13 AM
eDizzle's Avatar
good advice, mental note....no vibrant!
skaternak
19
Nov 24, 2009 04:07 PM
vr4twinturbo
Nov 27, 2006 06:48 PM
vteec
Jan 27, 2005 08:44 AM
Nocide_Eluded
May 20, 2004 08:26 AM
B20ZSI
Jan 31, 2004 04:02 PM
