Godridge SS Lines Crack....
I just installed Godridge SS lines on my hatch with Em1 rear brakes... the diference is amazing... however i start to feel the brakes softer and softer , so i check everything and i find a small crack on one of the lines, where the fitting rest on the caliper the (neck). after contact Godridge they ask for some basic info and prove pics etc, i send them the pics and the request as follows...
Re: goodridge lines,
Sent: Mon 3/29/10 1:54 PM
To: josue acevedo (josue.acevedo@hotmail.com)
Hi Josue,
Can you send me a picture of the defective part? Can you give me the kit number you received so that I can look at it? We can send you a replacement line if the line is defective.
pics sent......
next day.....
RE: goodridge lines,
Sent: Tue 3/30/10 4:33 PM
Josue,
Thanks for the pictures. Looking at the cracked fitting, you can see chafing marks as if the fitting was hard up against the caliper. It appears that this pressure is what caused the fitting to crack. Regardless, I will send you a replacement line, I just need your address.
Karl
Reply by me...
. the mark in the line is were the curve rest on the caliper... the ones from factory has this chafing mark, remember this curve is design to rest in the caliper for no movement. but thanks for your loyalty to the customers. Thanks again....
i just posting this cause this is the big difference between small company or just knockoff parts and big company's and good product...not only the quality but the customer services to..thanks again Karl.....!!!!!!!!!!!!
Hi Josue,
pics sent......
next day.....
Josue,
Karl
Reply by me...
Marvin1985
Suspension & Brakes
Jan 15, 2014 08:22 PM
