if you go turbo...what is it that you....n.....
Old Sep 9, 2002 | 02:38 PM
Ideal's Avatar
Default if you go turbo...what is it that you....n.....
When you goto turbo, i hear you yield better going with a custom setup, now, what do you need to get when you get a turbo set up, custom.... also what things should you do to your car, as in internals, and whatever else to get a everyday good level of boost for you car. What parts are recommended when going turbo?
jon
Old Sep 9, 2002 | 02:39 PM
Accord94DX's Avatar
Default Re: if you go turbo...what is it that you....n..... (Ideal)
The only custom part of my next turbo kit will be the credit card i order it with.
Old Sep 9, 2002 | 02:40 PM
Ideal's Avatar
Default Re: if you go turbo...what is it that you....n..... (Accord94dx)
so your going, custom numbers of a credit car ae....sounds life fraud....someone on my q?
-jon
Old Sep 9, 2002 | 02:41 PM
Gennady's Avatar
New User
Upgraded valve-train, resleeve cylinder walls, upgrade valves, seals, rods, piston rings, maybe lower CR.
Custom turbo setup is better because you could customize all of the components. Sorta like, would rather have a Compaq with set peramiters and parts from the factory, or would you rather have a Dell build to your specs?
Old Sep 9, 2002 | 02:42 PM
93accordEX's Avatar
I believe hes getting at the fact that sometimes a custom turbo can be a complete bitch and in come cases you may as well just get a kit that has been proven to do what it claims and have much less of a headache and just bolt it on.
Old Sep 9, 2002 | 02:43 PM
Ideal's Avatar
Default Re: if you go turbo...what is it that you....n..... (Wont be beat)
built all my computers, im A+ and CCNA Im actually in my ccnp class right now. So what parts do you guys recomend on the actual turbo custom set up? Possble for dual-tubo's ae?
heh
jon
Accord94DX's Avatar
or, with my luck:
Get your $2,000 computer setup with no/broken internals.......
Accord94DX's Avatar
Default Re: if you go turbo...what is it that you....n..... (93accordEX)
amen.
Old Sep 9, 2002 | 02:46 PM
Gennady's Avatar
New User
Give it up dude. You are no where near this level. If you want this answered well, go to F/I, but dont mention the dual turbo thing because you will be clowned....your not driving a Supra.
Old Sep 9, 2002 | 02:49 PM
GimpyAccord's Avatar
well he must be thinking Biturbo.. but on a such a low displacment/hp car that would be a total oddity/waste of time.. you'd need 2 really small turbos and a big imagination.
I'm doing the ... ... ... ill famed DSM manifold "custom" (read: ghetto) turbo on my car. heh... let ya know how it turns out in a month or so.
edit: i'm doing it this way because my woman will NOT let me spend 2000+ dollars on a turbokit for a 1000 dollar car.
[Modified by GimpyAccord, 3:49 PM 9/9/2002]
Old Sep 9, 2002 | 02:50 PM
3700 Vtec's Avatar
You'll spend more time looking for and waiting for parts than you'll want to, though it would be nice.
Old Sep 9, 2002 | 02:51 PM
Gennady's Avatar
New User
Default Re: if you go turbo...what is it that you....n..... (GimpyAccord)
WWhoooppaaaa!
Old Sep 9, 2002 | 02:52 PM
Default Re: if you go turbo...what is it that you....n..... (3700 Vtec)
so far i have about 500 invested in my turbo project.. and i have every major component except managment system (which will prolly be the ... ... ... vafc 'hack'). The only other thing i lack is plumbing which is a no brainer. Just waiting for winter to start... winter beater (88 Escort GT) has a limited life span.
I cant wait to hear this lil guy spool up. I'm not going for 696969hp .. i just want a lil bit o' boost.
[Modified by GimpyAccord, 3:56 PM 9/9/2002]
Old Sep 9, 2002 | 03:01 PM
Gennady's Avatar
New User
That a new hoover vaccuum cleaner? No, wait, I know...its a deluxe copy machine!
Old Sep 9, 2002 | 03:08 PM
niedejb's Avatar
The reason I went kit was for the piping.
I should have gone with custom since I dont even use the fmax fuel stuff.
Old Sep 9, 2002 | 03:49 PM
do nawt mock my poor little turbo
i hear that brother.. piping is easy and all, but its a matter of how it'll look when you're done. for my IC -> TB piping i'm just using my old generic CAI, and have had a Greddy BOV flange welded to it.
Old Sep 9, 2002 | 03:52 PM
Brandon's Avatar
Life is Suffering
Well, in my dorm room I have most of my setup together. I have an F-Max mani, HKS wastegate, T3/T4 turbo, and on the way an R33 core for the intercooler.
Old Sep 9, 2002 | 04:52 PM
Ideal's Avatar
I was just kidding about the dual dude, check out the "heh" at the bottom of that post. jeebus!
jon
Old Sep 9, 2002 | 06:09 PM
Nick M's Avatar
why are you kidding about the dual? DRT from Woodside, NY runs a low 9 second twin turbo civic
Its not the easiest way to go about going fast, but if those guys can ever dial in the chassis and get it tuned right then it will be among the elite FWD Honda drag car for sure.
Old Sep 9, 2002 | 06:11 PM
Gennady's Avatar
New User
Default Re: if you go turbo...what is it that you....n..... (HondaSport)
Ever seen a 4th gen engine bay? Gotta replace the radiator and fans just to get one turbo in there. 2 is impossible without major modification to the chasis.
Old Sep 9, 2002 | 07:28 PM
paul9luap's Avatar
Default Re: if you go turbo...what is it that you....n..... (F22turbo)
I have you beat. I've got a 92 lude SI h23 longblock sitting on an engine stand in my dorm room. Actually, I ordered it today, so it won't be here for another 2 weeks or so, but it will sit in my dorm room while it gets built up and worked on.
Old Sep 9, 2002 | 07:46 PM
psyphre's Avatar
I won't, I'm gonna do the same in the spring. Lots of DSM part up here in the great white north :D
Old Sep 9, 2002 | 07:54 PM
paul9luap's Avatar
Default Re: if you go turbo...what is it that you....n..... (psyphre)
Hey, I'm going to Toronoto for October Break. I've heard lots of clubs!
Old Sep 9, 2002 | 08:03 PM
psyphre's Avatar
Default Re: if you go turbo...what is it that you....n..... (paul9luap)
TONS of clubs, normal and strip.
Old Sep 9, 2002 | 08:19 PM
paul9luap's Avatar
Excellent.
