Red Honda Emblems for EP3 not fitting USDM 04 SI...PLEASE HELP!!
Old Mar 30, 2010 | 01:41 PM
skindeep's Avatar
Default Red Honda Emblems for EP3 not fitting USDM 04 SI...PLEASE HELP!!
Can someone verify why the red H's that I purchased from ICBMOTORSPORTS do not fit my 2004 EP3? I thought I read somewhere that the 04-05 front "H" is slightly bigger than the 02-03. Also, I figured that the back "H" would be the same, how come the red "H" that I purchased looks to be somewhat smaller in size. Part numbers of the "H's" are 75700-S5T-E01 and 75701-S5T-E01. Has anyone else had these issues?
Old Mar 30, 2010 | 02:11 PM
charleso's Avatar
Default Re: Red Honda Emblems for EP3 not fitting USDM 04 SI...PLEASE HELP!!
you are right, 04-05 H's are bigger than 02-03 H's for the front, but that only goes for the real type r's because they have different grills. You have to get the 02-03, the smaller one, to fit your usdm grill
Old Mar 30, 2010 | 02:22 PM
skindeep's Avatar
So since I have an 04-05 USDM EP3, I either have to upgrade to the Type R grill to fit the bigger "H" or downgrade to the 02-03 USDM grill to fit the "H" that I ordered? I was told that the one I currently have should fit, but it does not and If i want to go bigger then I have to go with the bigger one (coke size H). Is there not one out there that fits my current size? How come the back one is also smaller?
Old Mar 30, 2010 | 02:39 PM
charleso's Avatar
All stock usdm grills are the same on all ep3 si's, aside from matt or glossy finish. You need the red H from a 02-03 type r to fit your grill. When installing the front H, are you aware that you are supposed to take off the stock H and the backing supporting it. Once you take that out there should be a place to put the red H.
I checked the item numbers, it seems that you got the correct H's
Old Mar 30, 2010 | 02:51 PM
skindeep's Avatar
Post a link to which H you bought, so i know which one you have exactly
Here are the links to where I purchased the "H's"
Front - http://yhst-1408381693991.stores.yah...cityrredh.html
Rear - http://yhst-1408381693991.stores.yah...cityrep3r.html
I thought that I would be able to just place the red "H" on after removing the stock "H". So if I remove the back support, then it should fit? What bout the rear? How come it looks smaller?
Old Mar 30, 2010 | 02:57 PM
charleso's Avatar
so you got the correct red H's. just remove the backing by taking out some screws from behind the grill.
take this off, and there will be a place for the red emblem.
Old Mar 30, 2010 | 03:03 PM
skindeep's Avatar
Thank you very much. I will remove that piece to see if it will fit. How about the rear emblem, the red "H" looks somewhat smaller. Should it just fit right in?
Old Mar 30, 2010 | 03:18 PM
charleso's Avatar
rear should fit once you take out the stock one
Old Mar 31, 2010 | 04:16 AM
turboteg2nv's Avatar
lol
It's funny you're telling us it doesn't fit, when you haven't even removed the old emblems yet..
Old Mar 31, 2010 | 04:18 AM
SickSi99's Avatar
D'oh!
Old Mar 31, 2010 | 06:38 AM
skindeep's Avatar
Originally Posted by turboteg2nv
lol
charleso - Thanx for you your help with this. It is very much appreciated.
Turboteg2nv - the issue here is that I basically put the emblem up to the one in the rear and it looked smaller. I didn't want to remove the stock one and open the red "H" from the package, just in case I had to return it. You should understand that much... right?
Old Mar 31, 2010 | 07:03 AM
skindeep's Avatar
Can you show me a picture of how the "H" looks like on your 04-05 SI? I am assuming you have one since you have the picture there.
Old Mar 31, 2010 | 09:17 AM
I guess.
I usually do my research before I buy something, that way I know for sure it will fit and I won't have to return it. Then I don't have to go on the internet and make a thread about how I'm skeptical if it will fit or not before I've even tried it.
But that's just me.
Old Mar 31, 2010 | 09:38 AM
charleso's Avatar
i have the red H on my 02-03. doesnt matter since all si grills are pretty much the same.
Old Mar 31, 2010 | 10:22 AM
skindeep's Avatar
I guess.
But that's just me.
What are these forums for? Is it not to help someone else out even if its for something as simple as this?
Old Mar 31, 2010 | 10:23 AM
skindeep's Avatar
Thanks a bunch.
Old Mar 31, 2010 | 11:10 AM
It's been posted before. Quite a few times actually.
Kinda goes hand in hand with doing research before you buy something (AKA looking it up online to see who's installed it before)...
You'll learn eventually. I hope.
Old Mar 31, 2010 | 11:23 AM
https://honda-tech.com/forums/showth...d+Honda+emblem
https://honda-tech.com/forums/showth...ght=red+emblem
lulz
Old Mar 31, 2010 | 01:43 PM
lostniraq25's Avatar
yeah it looks smaller, but it fits perfectly in there. And like stated above the USDM grilles all share the same red H.
Mike457
Sep 26, 2017 12:50 AM
teddy_dc2
Sep 22, 2006 10:27 AM
strepto
Acura TL, RL & ZDX
Aug 5, 2005 01:49 PM
