what size injectors??
so im almost done with my build and im wondering what size injectors i should run. im building a poor mans type r with a fair amount of mods but nothing crazy.. and im running a turbonetics t4 hybrid turbo. i will be running around 12-14 pounds max. what size injectors would you recommend for this build
It depends mostly on what your power goals are...but sounds like you're not building anything too crazy so yeah, 440-450CC Injectors should be just fine. Most people just buy DSM injectors--you can find them on e-bay for pretty cheap.
ha yea thats exactly what i had in my last build before i blew it up.. the dsm 450cc injectors worked just fine but idk if there very dependable and whether i should look into a set of densos or pte's. i never had a problem with the dsm injectors but do aftermarkets have any better results??
I'd say at LEAST 550's....round der...I had a mild build(t04e Garret, stock head wit je pistons and eagle rods) 15lbs wit hondata...352whp fan perfect for like 3years before I wrcked it..oops! Haha but naw...I say it's better to have just a lil bigger den u "need"
-I meant to provide this earlier...this goes along with what I said earlier: it depends on your power goal. This is what Innovative Motorworks suggests:
240cc = 175whp or less
310cc = 175whp - 250whp
440cc = 250whp - 300whp
550cc = 300whp - 375whp
880cc = 375whp +
880cc = 375whp +[/QUOTE]
GREAT post!!!!!!
GREAT post!!!!!!
im a fan of RC injectors im throwing a set of 750cc on my teg
but my power goal is 350 hp or so with my teg build
i also like the idea of going just a little bit bigger than what you think you need better to be bigger and safer than going to small 500-550cc sounds about perfect but again all depends on waht kinda hp your think you will be putting down
See Are X
Dec 14, 2005 07:29 AM
SpeedMonkeyRacing
Aug 16, 2003 06:32 AM
