Steering Problem
Hello HT
i feel my car steering is moving on some roads, its not shaking, just like its not smooth like it used to be, i check all the car's bushing and they are good.
what is the problem and how can i fix it?
my car is 1998 lx with FK lowering springs and 16" work wheels
adjust the steering rack!! look at your rack, you'll see a 40mm nut and a 14mm bolt inside of it. loosen the 40mm nut then tighten inward the 14mm bolt. After bottoming out the 14mm bolt in undo it a half turn or so...take your car for a spin and check the steering, you may have to do this a couple of times until you are happy. This really worked for me. USE JACK STANDS!!
^MikeG
May 23, 2006 08:40 AM
