Speedometer not working after h22a swap
Old Mar 29, 2010 | 06:31 PM
JibrilsAuto's Avatar
Default Speedometer not working after h22a swap
Just did a H22A swap in a cb7 93 coupe ex 5 speed, my speedometer is only working sometimes. I replaced the vehicle speed sensor since i had two one from f22 and one from h22. Its a h22 tranny when I first put it in the needle went up as if its going to work jumped around and then back down to 0. Can someone give me any ideas to what I should do to solve this problem. I have no vtec untill i get this problem solved.
Old Mar 29, 2010 | 10:11 PM
Blue94Accord's Avatar
Default Re: Speedometer not working after h22a swap
bad wiring. the pin in the sensor is stuck? bad sensor?
SoFresh1189
Aug 3, 2012 10:35 AM
732xghost
Nov 14, 2008 02:44 PM
viet_tec
Aug 12, 2007 01:16 PM
