92 lude tranny prob?
Hi ,
When I shift into D4 from park indicator light D4 flashes green and runs like ****.....Then I down shift to 1 and manually shift. works ok but not right. any ideas?
The D4 light flashing means that the TCM (transmission control module) has
detected a problem. You will need to jump your service connector so you
can read the code/s, which will let you know what the problem is.
glenn380
Dec 30, 2009 01:23 PM
