Function form type 1 wont go low on my 90 hatch?
Old Mar 29, 2010 | 01:39 PM
Jdmsolutions's Avatar
Default Function form type 1 wont go low on my 90 hatch?
just wondering if anyone else had this problem with the new style type 1 full coil from f&f, i have the lower perch all the way bottomed in the front and still have about an inch of wheel gap? i called them and they say change the spring perch.. but it says that also voids warranty? so idk.. anybody shed some light? or know if eg forks witll lower me a bit more and fit around the ef shock tube?
Old Mar 29, 2010 | 11:44 PM
Default Re: Function form type 1 wont go low on my 90 hatch?
pmub
Old Mar 30, 2010 | 01:14 AM
BiG ChOr!Zo's Avatar
either void your warranty or get some type 2's...problem solved
Old Mar 30, 2010 | 01:18 AM
Fo-Do Fanatic's Avatar
Take one collar out and flip the spring, done. If they blow, put the collar back on and flip the spring back the right way and get a new one
Old Mar 30, 2010 | 08:53 AM
so i take it this is a common problem on the ef?
Old Dec 26, 2011 | 09:36 PM
FSS13foxtrot's Avatar
I have the same problem, got mine 2 weeks ago, lowered it in the rear without messing with the perch. front i did the same, and have about an inch and a half gap, whereas the rear is slammed nice. I lowered the front perch afterwards an inch and i still got the same issue. I have been told to get EG forks and open it up a big to slide it down more or cut off the perch locking ring then lower the perch to the sleeve lock . Another route i have heard of is to go with aftermarket lowering forks.I have not decided which route to go however the EG forks seems more promising and available easier for me.I will update
Old Dec 26, 2011 | 11:25 PM
Stunna MIKE's Avatar
Eg forks and ef forks are the same height. Eg forks where the shock slides in is a lot wider as the eg / dc shock bodies are fatter and talller.
What I would recommend you do; I've never had FF's so I don't know how many lock rings they have. But I would remove all but one, lower as much as it could go and get some extended top hats so you won't bottom out and you will hav more shock travel. I just did this with my brothers omni powers on his da. I got them for an eg a few years back, we put them on his car tonight and it wouldn't go low enough. So we did what I just said. Hope this helps!
Romo Pyro
Oct 21, 2012 07:03 AM
smokinloc
Suspension & Brakes
Jan 27, 2010 04:54 PM
viciousef9
Suspension & Brakes
Mar 31, 2009 10:23 AM
4thgenlude
15
Oct 24, 2004 08:44 PM
scorched0
Mar 19, 2004 06:24 AM
