Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Fire Suppression Systems, Free Shipping on all ESS Fire 2.3L and 5.0L Systems!
Old Mar 29, 2010 | 01:24 PM
Safe Drives's Avatar
H-T Basic Sponsor
Icon3 Fire Suppression Systems, Free Shipping on all ESS Fire 2.3L and 5.0L Systems!
ESS 2.3 Liter Fire Suppression System.
$409 with free shipping to the lower 48 states, USA. LINK
The ESS 2.3 liter system is approved by SCCA, NASA, PCA, BMW Club, and others for competition and track days.
This is a 3 nozzle system utilizing our T-style nozzle design, a bulkhead tee fitting for two nozzle coverage of the engine compartment, all fittings, stainless steel mounting brackets, pull cable activation, our re-designed pull cable mounting bracket for easy installation, 10 ft. aluminum tubing, and detailed instructions
This system is a two zone system. It is designed to give protection to two zones in the event of a fire - most commonly the driver and the engine. In place of the engine the fuel cell could be the second zone.
Key Benefits
Excellent coverage through the use of the new T-style nozzles
Field rechargeable in under a half hour
Easy to remove for technical inspection
Included Parts
Spun cast aluminum cylinder Aluminum 2 port head
Slotted pull cable bracket Adjustable length pull cable
Safety cup and pin for pull handle Safety pin for cylinder actuator
2 -4 AN to 1/4" NPT head fittings 1 -4 AN bulkhead tee and nut
8 -4 AN nuts and sleeves Insulated "D" clamps
10ft. 1/4" aluminum tubing
3 T-style nozzles
2 Stainless steel t-bolt band mounts with integrated feet
Non-fracturing head seal
8 oz. AFFF concentrate
Emergency "E" sticker
Detailed, illustrated instruction manual
Made in the USA
WARRANTY: Emergency Suppression Systems, Inc. certifies to the first end-user that the ESS product they purchased is free from defects in material or manufacturing, under normal use, for a period of three years. If the product is found to be defective during this warranty period, ESS’s liability and the purchasers sole remedy shall be at ESS’s option to (1) repair or (2) replace the product or (3) refund the purchase price of the product,, after the product has been returned to ESS with the proof of purchase. If the failure is determined to have been through misuse, abuse, accident, neglect, mishandling, or modification of any kind, ESS will have no responsibility to repair. replace, or provide refund for the product.
ESS 5 Liter Fire Suppression System.
$509 with free shipping to the lower 48 states, USA. LINK
The 5.0 liter system is a racing approved system by SCCA, PRO-SCCA, Trans Am, World Speed Challenge, American LeMans, NASA, and others.
This is a 4 nozzle, 3 zone system utilizing the newest T-style nozzle, bulkhead fitting, 20 ft of aluminum tubing and the other features of the 2.3 liter system. This system is available as an owner rechargeable system and as a SFI 17.1 compliant system. The SFI 17.1 compliant system requires that the systems be shipped full, sealed, and certified for 2 years of service. We offer a re-certification program for both 17.1 and non-17.1 systems. Call our offices for more information or request information by writing to info@safedrives.com.
This system was created for the hardcore racer. It is designed to provide three zones of coverage - driver, engine, and fuel cell. The aluminum cylinder and hardware keep down the weight and yet the 5 liters of suppression agent provides better coverage than the competition. The 5 liter system will produce approximately 30 liters of foam when activated, enough to subdue the most stubborn fire. In non SFI 17.1 compliant systems, you clean up with water and can recharge the system at the track with a recharge kit (retail under $70) and fresh water. The SFI 17.1 compliant version of the 5.0 liter system requires that the system be shipped back to us for recertification. We offer a re-certification program for both 17.1 and non-17.1 systems. The stainless steel t-bolt mounting brackets allow easy access for tech inspection and storage during the off season.
Contact your sanctioning body if you would like to use this system.
Key Benefits
Larger coverage area than the 2.3 liter
Meets or exceeds most sanctioning body requirements
It is also available in AFFF-AR for use on alcohol based fires
Included Parts
Aluminum 3 port head
3 -4 AN to 1/4" NPT head fittings
10 -4 AN nuts and sleeves
20ft. 1/4" aluminum tubing
4 T-style nozzles
12 oz. AFFF concentrate
Made in the USA
Old Mar 31, 2010 | 10:17 AM
H-T Basic Sponsor
Default Re: Fire Suppression Systems, Free Shipping on all ESS Fire 2.3L and 5.0L Systems!
Bump for free shipping!
Old Apr 1, 2010 | 02:30 PM
H-T Basic Sponsor
*awsome prices on great products*
Old Apr 9, 2010 | 12:34 PM
H-T Basic Sponsor
OK H-T... The next order I take over the phone that mentions this advert and orders a ESS Fire System, I WILL TAKE 10% OFF ENTIRE ORDER! CAGES TOO! I WILL EDIT THIS POST ONCE THE ORDER HAS BEEN PLACED.
THERE IS ONLY ONE AT THIS PRICE!!!!!!!!!!!!!!!!!!!!! YOU?!?!?!?!
Old Apr 13, 2010 | 11:28 AM
H-T Basic Sponsor
http://safedrives.com/proddetail.asp...8ResQMe&cat=13
Old Apr 14, 2010 | 02:18 PM
H-T Basic Sponsor
bump
Old Apr 26, 2010 | 10:38 AM
H-T Basic Sponsor
Originally Posted by GSaura
Thanks, Charles! Got some G-Force harnesses and mounting goodies in the mail today. That was fast! Can't wait for the roll bar to get here.
Thanks to you for the order!
Old Apr 28, 2010 | 07:45 AM
H-T Basic Sponsor
Safety 1st!
Old May 3, 2010 | 10:43 AM
H-T Basic Sponsor
bumps!
Old May 4, 2010 | 08:44 AM
H-T Basic Sponsor
Bump!!!!
Old May 11, 2010 | 07:25 AM
H-T Basic Sponsor
We have roll bar and roll cage kits available for most Honda or Acura cars.
BOLT IN Click here! Starts at $399.95!
WELD IN Click here! Starts at $169.95!
PADDING Click here! Starts at $18.95 for a 3 foot long section SFI 45.1 Certified.
Autopower 6 point "U-Weld" cage kit shown.
We have the widest selection of roll bar and roll cage kits available in the North America.
Drag race NHRA legal 8 point roll bar kits starting at just $169.95! Why wait?
PM me with any questions or just call toll free 877-739-1713.
Charles
Old May 18, 2010 | 02:56 PM
H-T Basic Sponsor
https://honda-tech.com/forums/wheels-tires-brakes-suspension-48/stock-gforce-race-gear-sale-combo-packages-all-orders-over-%2499-%3D-free-shipping-2593652/
Old Jun 1, 2010 | 12:49 PM
H-T Basic Sponsor
Bump!
Old Jun 2, 2010 | 08:50 AM
H-T Basic Sponsor
Bump!
Old Jun 3, 2010 | 09:46 AM
H-T Basic Sponsor
Bump!
Old Jun 8, 2010 | 02:03 PM
H-T Basic Sponsor
Questions welcomed.
Old Jun 9, 2010 | 11:24 AM
H-T Basic Sponsor
Only selling safety products since 2005.
Old Jun 16, 2010 | 07:42 AM
H-T Basic Sponsor
bumps
Old Jun 17, 2010 | 08:16 AM
H-T Basic Sponsor
Questions welcomed.
Old Jun 21, 2010 | 08:03 AM
H-T Basic Sponsor
Thank you H-T members!
Old Jun 22, 2010 | 07:42 AM
H-T Basic Sponsor
Key Benefits
Included Parts
3 T-style nozzles
Made in the USA
Key Benefits
Included Parts
4 T-style nozzles
Made in the USA
Old Jun 23, 2010 | 09:27 AM
H-T Basic Sponsor
Old Jun 24, 2010 | 12:06 PM
H-T Basic Sponsor
Safety bump.
Old Jun 25, 2010 | 10:07 AM
H-T Basic Sponsor
This are awesome safety products folks!
Old Jun 28, 2010 | 12:59 PM
H-T Basic Sponsor
Questions welcomed.
