d16a6
Old Mar 29, 2010 | 11:57 AM
mase1386's Avatar
Icon2 d16a6
i want 2 put a d16a6 in my ef it came with a d15b2. I want 2 use the same wiring. So will my intake and exhaust manifold off my dual point bolt up 2 it? or also should i get a zc instead?
Old Mar 29, 2010 | 12:03 PM
D16SiHatch's Avatar
Default Re: d16a6
are you wanting to replace it because the d15b2 is broken? if you just need the car running then yes you can use the dpfi intake, exhaust, etc. however if you want the car to be as quick as the a6 was stock, you'll have to convert to mpfi.
Old Mar 29, 2010 | 12:10 PM
mase1386's Avatar
Icon2 Re: d16a6
ya it has a blown head gasket and i need my car back and im doin the swap myself. I plan on doin the conversion later i jus need 2 get by for now. and the local honda speed shop here sells all single cam motors for 495 bucks.do u prefer another single cam over the d16a6
Old Mar 29, 2010 | 12:12 PM
alx_90ef's Avatar
Default Re: d16a6
wel l other single cams are better. but need more parts to make them work properly.
the d16a6 is probably the one you want if your going to keep all your stock parts.
but 495 is alot for a d16a6
Old Mar 30, 2010 | 07:58 AM
mase1386's Avatar
Default Re: d16a6
where is a good place 2 get one then for cheaper. hmo doesnt even carry them
Old Mar 30, 2010 | 09:53 AM
D16SiHatch's Avatar
Default Re: d16a6
since i assume you are in a hurry and need it running asap you might be stuck with buying that a6 for $500 :/ if i were you i would hold out as long as possible though and try to find one on craigslist for a LOT less. for $500 you could easily pick up a z6 longblock.
Old Mar 30, 2010 | 09:55 AM
alx_90ef's Avatar
Default Re: d16a6
i agree with D16SiHatch
500 for a a6 is too much. i think i just saw one on CL for 250
Old Mar 30, 2010 | 11:32 AM
acmoc's Avatar
Default Re: d16a6
hmotors.com
get the sohc zc
Old Mar 30, 2010 | 11:57 AM
mase1386's Avatar
Default Re: d16a6
ok thanks. I jus gotta do somethin quick. cuz i bought my ef wit a blown head gasket. and my crx has a burnt ring. I should of never got rid of my da.
Old Mar 30, 2010 | 12:17 PM
alx_90ef's Avatar
Default Re: d16a6
just change the head gasket
Old Mar 30, 2010 | 12:24 PM
acmoc's Avatar
Default Re: d16a6
eaasier to swap the motoor tthan the head gasket =]
Old Mar 30, 2010 | 12:33 PM
alx_90ef's Avatar
Default Re: d16a6
not really if you know whats up and have all the proper tools and parts it'll rather quick
Old Mar 30, 2010 | 12:37 PM
mase1386's Avatar
Default Re: d16a6
i got the tools and everythin i have a lift and everything. i got a shop but there is water in the oil..
Old Mar 30, 2010 | 12:44 PM
DCRB's Avatar
Default Re: d16a6
not really. pull head off, have machine shop check it, get head back a day later and put head back on with new head gasket and head bolts. then just run a thing or two of engine flush through the engine if you have a bad case of milkshake (or just use a bunch of brake cleaner with the pan dropped)
Old Mar 30, 2010 | 12:47 PM
mase1386's Avatar
Default Re: d16a6
the machine shops around here have bad reps. I called one and they wanted like 200 and thats bringing the head in bare
Old Mar 31, 2010 | 07:09 AM
acmoc's Avatar
Default Re: d16a6
Is the head really warped bad?
You can probably use the 9d16a6 head gasket which is thicker and will seal better
Old Mar 31, 2010 | 01:08 PM
BeefyEK9's Avatar
Default Re: d16a6
out here in sb by cal state theres a machine shop that did my ls head for 25 bucks and it only took like 10 minutes an i got it back..
Old Mar 31, 2010 | 01:17 PM
mase1386's Avatar
Default Re: d16a6
what shop. i live in sm santa maria so im not 2 far
Old Mar 31, 2010 | 07:32 PM
SiRJoEy's Avatar
Default Re: d16a6
That's alot for an a6 but they are kind of hard to find though.you can find a z6 or if lucky a y8 for that price. Or just get d15 vtec.I got my complete z6 for 250 on craigs.
Kmorg300
Jan 29, 2014 03:35 PM
tripwire401
Jul 6, 2012 02:15 PM
mase1386
Mar 26, 2010 03:02 PM
slocrxsi
May 24, 2004 08:05 PM
90civichb
Jan 28, 2003 03:49 PM
