EJ1 Part out
Old Mar 28, 2010 | 10:21 PM
street_racer_271's Avatar
Default EJ/EG Part out, updated daily
****************Updated daily****************
********** HUGE GARAGE CLEARANCE **********
********* No Reasonable offers refused *********
Aparently ran out of bandwitdh on photobucket. So if you need any pictures, just ask, I can email, pm, or text them to you
Before you continue, I will NOT ship large items over seas, (doors, fenders, steering racks, sunroof, etc)
EJ1/EH2 Part out
Parts I'd trade for (all for a 92 Civic Hatch w/B18C1):
BYS Rear Spoiler
BYS Front Spoiler
J's Racing Front Spoiler
First Molding Front Lip
Spoon Carbon Kevlar Spark Plug Cover for B-Series
I'm up for any other things you might have
Parts For Sale
92-95 Civic Parts
PWJDM Bumper Quick Release, only red left - $30 shipped
Blitz Oil Cap - SOLD
HKS Oil Cap - SOLD
PWJDM Oil Cap (Silver left - $40
MoTeC M84 ECU keychain - $14
Front Caliper brake pad retainers Part #45237-ST7-003 - $22 for all 4
Front Caliper rebuild kit Part #01463-ST7-000 - $53.38 for both
EF/EG/DA/DC Rear Lower Tie Bar. Polished, also have an EK Beaks bar that I stripped to paint - $100 shipped
USDM Left Side Headlight, OEM Stanley - $30
Grey Shifter Console - SOLD
Grey Ebrake Cover - SOLD
Grey Center Console - $10
Grey Sun Visors - SOLD
PR4 ECU - $20
P06 ECU - SOLD
92-95 Civic 2/3dr Door window garnish. Right side only. No broken Tabs - $15
Shifter console - $10 (has 3 small holes drilled on the right side), SOLD, SOLD. Shift Boots available for $5
Handbrake, Black - $15
Misc Pieces - $1 and up. Or free with purchase of anything else
Window Cranks, door handle trim, cup holders, lower dash pocket Sold
Switches - $5 ea, empty plates - $2
Dimmer switch sold, a hazard switch sold
USDM Clocks - $15ea, Dimmer switch combo - $10, Power Mirror switch - SOLD, Defrost buttons - $5, Hazard switch - $5
OEM freshly powdercoated 2 post mount for 92-95 Civic, D-Series - SOLD
Dome lights - SOLD for Hatch Dome light, $2 for cracked lense, $5 for good lense
Steering Column, with working ignition switch, with key - $50
Hood release cable - $10
Gas release cable for coupe - $5
2x 13/16 MC and brake booster, can separate. - $20, or $10 each
Clutch MC, works with most honda's - SOLD!
Interior door handle, grey - $5ea
Exterior Handles - $5. right side sold
92-95 Civic Sedan Power Mirror Covers - $5 no broken tabs
Manual Mirror for 2/3 Door, Right side. 9/10 - $30
Manual Mirror for 2/3 Door, Right side. 6.5/10 - $10
Dead Pedal - $5
Climate Control Harness - $5
D16Z6 Oil Pick-up - $5
D16Z6 Cam Gear - $5
D16Z6 Camshaft - $30
D16Z6 Pistons, no cracks - $40
D15 Intake Manifold - Recycled
D-Series TB's - Recycled
SRS Clock Spring - $5
Hood release lever - $2
Hood Hinges - SOLD
Rear EG Speaker brackets - $5
Hood Latch - SOLD
Working fuse panel - $10
Cruise control steering wheel buttons - $5
94 Integra GSR Parts
3x GSR Cam Gears (PR3) - $5 each set
GSR intake manifold - $20
Other Honda
Heated Mirror switch, fits many 96+ honda’s - $10
Aftermarket Parts
BBS RS/RM Wheel lips. 0.5x15 30 bolt - $60obo
Hubcentric rings for aftermarket wheels - $10
Top mount Intercooler BOV adapter - $10
38mm Dump tube - $20
V-band Sheepey Built dump tube - SOLD
2.5" T-clamps - SOLD
2.5" Couplers - SOLD
T3/T4 Oil drain - $2 for slip on, $4 for threaded one
-10an weld on bung - $2
Misc Fittings $0.50 and up
Oil Pressure sensor - $5
Pivot RPM Limiter, no instructions - $10
Garage Built Fender Washers - $18
Battery Kill Switch - $10
Autometer shift light with shift pellets - $100
Sold Stuff:
D16Z6 Block and crank - - ejwoody
universal oil catch can - ej1serge
power steering delete kit from stealthmodeperformance, includes CBR1000 reservoir - bigkayej1
gauge cluster bezel, has small hole at the end - bigkayej1
mirror base - joon joon
3x corner lights dam's, and rktv
oem engine mounts - ejwoody
glove box handle - skat3h3ll
Idle Air Control Valve - EJ1-LUIS
R. Side Mirror block off plate - micheal
Generic short shifter, fits 94-01 integra and 92-00 civic - micheal
Suspension Techniques Front and Rear Sway Bars - micheal
GSR Power Steering Mount - d.yup
Virgin D16Z6 Wiring Harness - eg-perk
gsr rear sway bar, includes oem endlinks - j.packsb
8 lug studs - joon joon
Rear Trunk Garnish - PPE94
Side moldings - 91integra91
7/8" Brake Master Cylinder - 91integra91
93-95 Coupe Rear Bumper Filler Pieces - farfrumugen
4040 Prop Valve - jdmfactory
Autometer triple Gauge pod for 92-95 civics - Iwantacar
Manual Steering Rack - SLOW240
Brake Light Switch - AE86-PorscheGTS
92-95 Projector Headlights micheal
Window sill garnish (most clips intact, few broken) - b20ej1
93-95 Coupe Rear Seats, no rips or burns - b20ej1
EK JDM Style Headlights - local guy
D16Z6 Oil Pan – djknew09
OEM Engine Mounts– djknew09
Driver Side Door Handle - yellowone
Rear Dash w/Speaker covers - djknew09
Armrest - djknew09
Generic Red/Carbon fiber ebrake handle - local guy
Shifter console and cup holders - ravens20
Door handles in red – ravens20
Gas Lid Cover – ravens20
92-95 Civic Antenna, complete with gasket - alifestyle
OEM Style Fog Lights - ravens20
OBD1 GSR Throttle body - okBYE
Corner light socket - kyosoeg6
D16Z6 Crank Pully - just-ef-it
Interior Door Handle - [ej]Jonathan
Sunvisors - JDMTiger4
Momo Mozzi Hub - Daniel
Ractive Racing Steering Wheel (BNIB) - Daniel
Full-Race 6 Point Roll cage - ULLBSRY
License Plates - hatchetmancivic
D-Series Injectors - element04
OEM Tow hook - element04
Marshall Fuel Pressure Gauge w/90 degree elbow - sir_warrior
Purple B&M FPR - sir_warrior
OEM Radiator - Daniel
EG6/SIR Steering Wheel - mitch6
92 Civic Cabin Harness - Plateus
Taillight Covers - Plateus
Sun visors - Plateus
Gas cap - Plateus
MSD D16z6 Spark Plug Wires - Plateus
Intake/Coolant cross-over pipe - Plateus
D16Z6 Fast Idle Valve - Plateus
Sparco Speed Racing Seat with rails - Garrett Ainscough
Golden Eagle Rear Tow Hook - Garrett Ainscough
Benen Front Tow Hook - micheal
92-95 Civic 2/3 door hood - local guy
D16Z6 Intake Manifold - civicwagon4sale
EG SiR JDM Gauge Cluster - Jon Peters
Interior Door Handle cover - Jon Peters
Climate Control - Jon Peters
Passenger Side Vent - Jon Peters
Autometer Ultra-lite Pro Fuel pressure gauge and fittings - Jeremy Santos
Autometer Ultra-lite Pro Water Temp Gauge - Jeremy Santos
Hatch Taillights - MREG2
Innovative, left side 2 post engine mount, never been used - jdm ek o
Blox front camber kit - Riley Martens
Door Handle Covers - sohcturbo92vx
Aftermarket Racing Steering Wheel, Sparco Style - michael
AEM B-series Fuel Rail w/fittings - Pete Deorkson
93-95 Coupe Rain Gutter Moldings. Mint - jdmzoom
Combination switch, needed for horn to work on EG steering Wheel - jdmzoon
Megan Racing Cat-back exhaust with inline muffler (fits 93-95 Civic Coupe) - Matt Bezan
Energy Suspension Upper Control Arm Pivot Bracket Bushings - Jon Peters
Windshield moldings - Jon Peters
Sun visors, need cleaning - MonKK
Pair of 92-95 Civic Coupe/Hatch Fenders, primered - Tannan Riise
16" BBS RG023 rims - Evan
EP3 SiR cluster - Freeclowns
DC2 Vent with sunroof switch delete - Freeclowns
Integra Engine Mounts - Jeremy Santos
92-95 2/3dr Civic Fenders, no molding holes, oem Milano red - Rigs Sofronio
Black Window Cranks - Rigs Sofronio
Muteki Neo Chrome Open End Lug Nuts - Christopher Huynh
Black Shift Boot EG/DC - Local Guy
P72 GSR power steering pump - Tyler Barrett
Grey EG6 Steering Wheel - dodger
Agency Power Black Shift **** - Local Guy
T1R 12x1.5 Purple Open End Lug Nuts - Olaf
CF Vortex Generator Fins (Already removed) - suba03ru
Door Handle Trim - Carbcivic
Cup Holders - Carbcivic
Center dash pocket - MidasGuy
Dimmer Switch - MidasGuy
5 wire o2 sensor - Anousone
Din Pocket - Carl Causaren
Dimmer Switch - Adrian92
Shifter Console - 1tuffbb6
E-Brake Console - 1tuffbb6
Battery tie down - Ian Peters
Personal Neo-Eagle Horn Button - Matt Bezan
EM2/EP3 Wheels - Local Guy
GSR Dual bend Shifter - 90civicstdgold
D16 vtec solenoid - Local Guy
Power Steering Rack - Local Guy
EG/DC Side Markers - Matt Bezan
OEM EJ/EH/EG Front Lip - Matt Penner
93-95 Coupe Trunk, black - Matt Penner
Autometer Ultra-lite Pro Air Fuel Ratio Gauge - Local
Autometer Ultra-lite Pro Oil Temp Gauge - Local
Autometer Phantom Boost Gauge, never been used - Local
P75 ECU, non vtec B18B - Local
Black EG Arm Rest - 94CoupeNY
Full ignition switch with key, and matching lock set - rountreesj
Door speaker mounting cups - rountreesj
AEM Wideband Air/Fuel Ratio Gauge - Ian Rutherford
Shift **** with faux carbon fiber, matches the JDM Integra interior nicely - Local Guy
Seibon CF Hood Vent (Subaru) - joSTIzel
B-Series Torque/AC Mount - Ian Peters
EH2/3 Rocker Panel/Side Skirt - Jeff Toews
2/3dr 92-95 Civic Driver side window - Jeff Toews
92-95 Civic Hatch Taillights - rountreesj
Hazard Switch - rountreesj
Water Temp Sensor from D-Series - rountreesj
Taillight Covers for 93-95 Coupe - Agent4146
Sun Visors - recklessgoon16
Door Pillar Garnish, no broken tabs. Mint - ZEAL-SPORTS
Civic Seat Belts - ZEAL-SPORTS
Combination Switch - ZEAL-SPORTS
Turbosmart manual boost controller - Feriz
Stewart Warner Boos Gauge - Feriz
Shifter console - b0osted iinteg
Dash Piece - Stock90Civic
Climate Control - Stock90Civic
Manual Mirror Set L+R - Stock90Civic
Glove box - Randy Germono
Black Dashboard - Randy Germono
Shifter Console - Randy Germono
E-brake cover - Randy Germono
Shift boot - Randy Germono
Center Dash Piece, Missing Ash Tray - Randy Germono
NOS Remote bottle opener - eBay
Alpine SPS-1629S 6.5" Speakers. 120W Peak 30W RMS. 2 Way speakers - Dmitry
Rota Torque Wheels - Jonathan Cha
Hawk HPS Brake Pads, never used Part #HB242F.661 - Vincent Spence
D-Series Spark Plug Wires, - recklessgoon16
B20z -Robert Deleau
96-00 Civic Power Steering Pump - Dmitry
JDM Long Arm Rest - eBay
Energy Suspension Part# 16-3105, Lower Control Arm Bushings. BNIB - Justin Hoogie
ARP extended wheel studs 12x1.25 - Tyler Bergan
5spd Pedal conversion - j_boy32
Avid Torque Mount - Collin Funk
92-95 Civic Clutch Pedal - Tyler Barrett
Clutch MC, works with most honda's - Tyler Barrett
Dual Gauge pod, universal - Tyler Barett
P06 ECU - mofia77
P75 ECU - mofia77
Nuespeed Sturt Bar - Riley Martens
92-95 Civic Grey Glove box - Andrew Mason
eBay BOV - Jonathan Trakys
Turbo Couplers - Jonathan Trakys
Charge Piping for 92-95 Civic - Jonathan Trakys
Cast log manifold - Jonathan Trakys
Oil feed and drain lines - Jonathan Trakys
5 Bolt down pipe - Ian Rutherford
VTEC solenoid - Local
Automatic gear selector - Ertavarez
Driver side mirror - xivsavagevix
92-95 Civic Pivot Bushings/Mounts - 95egianp
Misc Shift ***** - Noah Perrin
8th Gen Civic/CSX Beaks Tie Bar - Andreas Kolb
Password:JDM EG Bumper duct - Urus
Ex/Si Cluster for 92-95 Civics - dis*****_g0tph0
B-series Engine Mounts - Riley Martens
Silver Mugen oil cap - John Skukan
Gold Blox 16pc Lugs - Derek Bergen
Universal Fuel Pressure Regulator - Derek Bergen
Password:JDM Red Tow Hook - Noah Perrin
Password:JDM Purple Hood Risers - nuthineasy88s
Password:JDM Purple Fender Washers - nuthineasy88s
Shift boot - Javlin42
Grey E-brake cover - Javlin42
Sparco Carbon Fiber Racing Pedals - Jaybee De Castro
Sickspeed Bumper quick release - Jonathan Vallarta
20pc Muteki lug nuts - Jason Moreau
92-95 Civic Hatch rear wiper - scuzz
V-band Sheepey Built dump tube - BlackCivicEX
Mugen Rad Cap - Stephan DaSilva
Volk Formula Rep Lugs - Stephan DaSilva
92-95 Civic Power Mirror Switch - Miguel Carrondo
92-95 Civic D.S. Power Mirror Interior Cover - Matt Foderaro
Skunk2 B-series Black Valve cover hardware - Matt Foderaro
92-95 Civic Antenna - Brian Chahs
92-95 Civic Hubcaps - Brian Chahs
185/70/14 Kelly All-Season Tires - Chris Mahon
Kicker 4 Channel Amp - Jason Bettess
AEM 2 1/2" Cold Air By-Pass (BNIB) - pelayo114
Grey Sun Visors - pelayo114
Dome light for Civic Hatch - pelayo114
Bumper hooks - Zaraki
Skunk2 Purple B-series Valve Cover Hardware - froggy123
EG6/SiR steering wheel - 89redrex
Din Pockets - 89redrex
Battery - Dane Loewen
Garage Built Tie Bar - John Skukan
Rear strut bar - John Skukan
Grey Arm Rest - Brady Penner
Black Glove Box - Brady Penner
OEM Headlights - Brady Penner
Passenger Door Handle - Brady Penner
Battery Tie Down - Brady Penner
EG/DC Hub - Joel Molgat
K24 Injectors and Fuel Rail - Ian Rutherford
HP Racing GSR Intake Manifold - Dylan Eikre
Pioneer CD Player - Garett Anderson
Oil Catch Can - RobMinhas
B-series header - Torrey Peters
Password:JDM Red bumper quick release - rjmancia
92-95 Civic hatch tailgate - Chazz Dawson
92-95 Civic N1 Style Axle-back - Chazz Dawson
Garage Built rear tie bar - Chazz Dawson
Rear Strut Covers - driguy
Rear Seat Latches - driguy
3 Switch Cluster - driguy
Gas/Hatch Release Handle Cover - Teg24
Skunk2 Silver VTEC Solenoid Cover - Cincitycustoms
Password:JDM Silver Rad Stay - Cincitycustoms
Cruise Control/Dimmer Switch - Robs_B18c
Password:JDM Rear Tow Hook - Ian Johnson
2 Post Mount - Ian Johnson
Password:JDM V.2 License Plate Relocator - Riley Motkaluk
Rear Hatch Taillight Access Panels - psychobear
EG6 Non SRS Steering wheel - Z19TH
Momo Tuner Steering Wheel - eBay
Password:JDM Purple Fender washers - Jayson Friesen
Password:JDM License Plate Relocater - Jasyon Friesen
Password:JDM Red Rad Stays - Jamie Reimer
Password:JDM Red Fender washers - Jamie Reimer
Password:JDM Hood Risers with Optional Hardware - eBay
Password:JDM Black Fender washers - DerekEJ1
Skunk2 B-series Valve Cover Washers - Rylee Blacklock
Spoon Colored K-Series Valve Cover - Riley Motkaluk
License plate relocator - Riley Martens
Takata Tow Straps - e.lo_
Project MU reservoir covers - Mitch Pope
Spoon reservoir covers - Donavon Kemppainen
Password:JDM Red Bumper Quick Release - Mitch Pope
Turbo Smart manual boost controller - Dylan Wall
Vibrant Valve cover breather filter - Dylan Wall
Skunk2 Low Profile K-series Valve Cover Hardware - Justin Peters
Mugen Formula Shift **** - Keegan Ivanco-Sinclair
Password:JDM Gold Bumper quick release - Keegan Ivanco-Sinclair
Mugen Logo Badges - eBay
Password:JDM Silver Bumper Quick Release - Dylan Wall
Password:JDM Red Hood Risers - Jesse Winder
Password:JDM Red Fender Washers - Jesse Winder
EG Door Cups - Freshdot
EG Window Cranks - Freshdot
32 Purple Password:JDM Fender Washers - civics4lyfe
Key's Steering Wheel - Colby Griffin
EG SiR/ITR rear lower control arms, bushings are minty - P.O.S P5
Energy Suspension Rear Lower Control Arm Bushings - Ian Johnson
Password:JDM Red Fender Washers - Ian Johnson
Function 7 Subframe Brace - Dre Grasdal
AEM FPR - Jordan McDougall
Benen Tow Hook Set - Daniel Balisacan
Purple Bubble Crystal **** - Daniel Balisacan
Silver Skunk2 LCA Hardware - Jay Thammavongsa
HKS Turbo Timer - Travis Jones
Password:JDM Black Bumper Quick Release - Mark Serdon
Blox lug nuts - Carlo Taruc
Blox Red open end lug nuts 12x1.5 - Boston Richardson
PWJDM Oil Cap - Boston Richardson
Mugen rad cap for aftermarket rad - Boston Richardson
Grey shifter console - Boston Richardson
Red and gold Password:JDM fender washers - Boston Richardson
PWJDM License plate relocator - Peejay Policarpio
Walbro 255lph fuel pump - Denzel Angermann
Pwjdm Purple Hood Risers - Denzel Angermann
Pwjdm Red Bumper Quick Release - Denzel Angermann
NRG B-Series Carbon Fiber Spark Plug Cover - Philipp Maxeiner
Muteki Neo Chrome open end lug nuts 12x1.5, 20pc. - Donavon Kemppainen
Dragon Ball Z Shift **** - Shawn Peters
Dragon Ball Z Shift **** - DJ Semperfi
Mugen rad cap for aftermarket rad - hondaem1si
HKS Oil Cap - sincityevo9
prefer paypal, everything is obo, if you don't like my price make me offer. All refunds are subject to a 10% restocking fee
some of things have been sitting in my garage for the last few years, so its just a little dirty. More pics available upon request.
Old Mar 29, 2010 | 11:14 PM
Default Re: EJ1 Part out
bump, added more stuff
Old Mar 31, 2010 | 10:56 PM
sold sway bars, april fools bump
Old Apr 1, 2010 | 09:50 PM
bump
Old Apr 1, 2010 | 11:09 PM
st0xafella's Avatar
bump
Old Apr 2, 2010 | 09:24 AM
tunedX's Avatar
Hey, is it possible to get just those Tach part off gauge clusters? Are those on KMs? What car those were from??
Old Apr 2, 2010 | 03:56 PM
from the EP3 cluster? the 2 dx clusters don't have tachs. I'm in Canada so we, and the rest of the world use the metric system. So yes its in KMs. The 2 dx clusters came from a 92 civic vx, and a 92 civic dx. The ep3 cluster came from a 01-05 Civic SiR
Old Apr 2, 2010 | 05:18 PM
eh vtec sc's Avatar
how much for the wire harness shipped?
Old Apr 2, 2010 | 05:38 PM
pm'd
Old Apr 5, 2010 | 07:09 AM
BUMP
a lot of interest in the EP3 cluster
Old Apr 6, 2010 | 04:13 PM
z6 engine harness pending
p72 p/s bracket sold
bump, still got lots left, and more z6 parts, just ask
Old Apr 7, 2010 | 11:04 PM
harness sold
bump
Old Apr 8, 2010 | 08:31 PM
bump
Old Apr 8, 2010 | 09:20 PM
JDM C.A.R's Avatar
how much for roll cage shipped
Old Apr 9, 2010 | 06:38 PM
i paid $100 shipping when i bought it
Old Apr 10, 2010 | 12:32 AM
JDM C.A.R's Avatar
OK NICE SO HOW MUCH ARE YOU ASKING FOR IT.
Old Apr 10, 2010 | 01:14 AM
JDM C.A.R's Avatar
oh my bad i saw the price i was in my own little world for a minute.lol
Old Apr 10, 2010 | 11:35 PM
bump
Old Apr 11, 2010 | 12:00 PM
ricky21's Avatar
Lots of good parts
Old Apr 11, 2010 | 12:53 PM
thanks, its a small portion of what i have in my garage, i keep adding more as i go
Old Apr 11, 2010 | 08:12 PM
bump
Old Apr 12, 2010 | 12:20 AM
JDM C.A.R's Avatar
man i really want that roll cage but the shipping is killing me 100 dollars is to much for me.
Old Apr 12, 2010 | 01:35 PM
its better than what i paid, I paid $600 for it shipped, then paid anothe $50 to get it powdercoated.
Old Apr 12, 2010 | 11:01 PM
bump
Old Apr 13, 2010 | 08:07 PM
bump, gsr sway bar sold
