In Quite the Predicament... (GSR with LS trans?)
A few days ago my timing belt slipped on my b18b1 due to a disfucntional tensioner, i think (in the process of tearing it down). I do not know if i bent a valve or if i need a new head, motor, or just a valve job. I guess we'll see
if i need a new motor might as well go vtec and get a jdm b18c lol
But on to my question: how does the ls tranny do with a gsr engine? Would it kill performance? I've heard the gear ratios are the same but does anyone run this setup?
Any help would be appreciated
if i need a new motor might as well go vtec and get a jdm b18c lolBut on to my question: how does the ls tranny do with a gsr engine? Would it kill performance? I've heard the gear ratios are the same but does anyone run this setup?
The gears are longer on the ls transmission. I found this cool Honda calculator, you can add the input and see the difference.
http://www.zealautowerks.com/transcalc.php
Thanks guys!
Ok second question: Where do you buy JDM engines? I know online but what are solid retailers? OR is there anyplace is washinton?
i'd check out hmotorsonline if you're trying to buy the swap, if you're going to spend a couple thousand on a swap, might as well just pick up a b16 or gsr trans for an extra 500
Yeah thats kinda what i was thinking now. The performance difference would make up for it. Might just sell the shell (super clean) and go buy a da or something
the only difference with a DA is that you'll need to track down a cable b16 or gsr trans unless you plan on doing the hydraulic conversion
